High Temperature Paint
Home > Topcoats
DiamondFinish Top Coat
KBS DiamondFinish is an extremely durable, rock-hard topcoat, designed to be applied over most metal and painted surfaces, including wood and concrete.
More Info from KBS Coatings
DiamondFinish ClearCoat
An incredibly tough and hard ClearCoat like no other on the market. This water clear high gloss clear coat remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
BlackTop :: Chassis Paint
KBS BlackTop is a permanent, moisture-cured, UV stable coating primarily used for topcoating surfaces previously sealed with KBS RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure.
KBS All-In-One Chassis Kit
$85.95
