| Perfect for spraying RustSeal into the inside of boxed frames, door panels, rocker panels, etc. Perfect for coating all of those hard-to-reach areas. |
- Specially designed for rustproofing auto bodies.
- Works with KBS RustSeal and most types of anti-rust coatings.
- Complete with adjustable nozzle which can be set depending on viscosity of liquid or coating in use.
- Used for applying KBS RustSeal to the inside of doors and panels.
- 1/4 (F) NPT air inlet.
- Underseal Gun
- 750 ml (26 fl oz) plastic container
- Flexible extension probe (36")
- Working Pressure Range: 87 to 145 PSI
- Air Flow Consumption: 13.5 SCFM (with standard nozzle)
- Air Flow Consumption: 6.5 SCFM (with extension probe)
Now you can get our helpful videos in pristine DVD quality, sent right with your order for only $0.95. This DVD includes eight episodes, showcasing our three most popular KBS products in everyday applications.
I used this gun and wand to paint the inside of the rocker panels on my 1971 Camaro. This gun and wand did a real fine job and with out fuss. I had tried to use a shutz gun and 3M wand before this and it just would not spray material consistantly and evenly like this gun. I thought I was out of luck until I found this one. I highly recommend it to anyone needing to paint inside hard to reach areas. |
Reviewed by: Craig B from Aiken, SC.
on 12/29/2009 |
Sparayed KBS rust seal on the inside of the two box sections of my chassis and the two trailing arm box sections. Not the prettiest of spary jobs but plenty of protection in very difficult long box sections. Need the flexible extension tube to reach all the corners. No other way to do this without the long flexible nozzle. Everything cleaned up well afterwards. |
Reviewed by: Ray R from Cincinati, OH.
on 6/3/2009 |
Worked great for spraying the inside of my frame. I used the Aquaklean and Rustblast first. Let it dry and then sprayed it. |
Reviewed by: Omar T from Lincoln, NE.
on 12/20/2007 |
| See All Reviews |
