High Temperature Paint
Home > What Others Are Saying About KBS Coatings
What Others are Saying about KBS Coatings RSS FEED
Customer Before & After Photos  |  See KBS Coatings in Magazines
Paul T. says .. 10/31/2008
I received an E-mail asking for feedback. One of the items was regarding Customer Service Suggestions. Are you kidding? You have the absolute best customer service I have ever encountered anywhere. All questions are answered thoroughly, politely and expertly. Your chat-on-line function is fantastic for when I have one of those "How am I going to do this?" moments mid-project. Thank you for the consistently expert advice.
PS: I've recommended your products to many others. I've showed them my "torture test" results. People can't believe the results. I wish I would have known about KBS coatings many, many years ago. It would have saved me a lot of do-overs after using your competitors' products.
^ Top
Mike S. says .. 10/11/2008
The kit worked perfectly. I had a smashed 5 gal HD softail tank. Cut it up into 10 pieces, narrowed, sectioned & chopped it to about 3.3 gallons. Mig welded the whole thing back together and coated the inside with KBS sealer.
Took a couple of afternoons to do the whole cleaning and sealing process, then let it cure for 4 days. Result? No leaks, no worries. What more can I ask for? Great product! I'm 100% satisfied.
^ Top
Brent P. says .. 10/2/2008
Hello, This past summer I purchased a KBS gas tank seal kit at the 'Back to the 50s" car show in Minnesota to repair the leaking tank in my '38 Plymouth. I subsequently purchased KBS Rustseal and epoxy putty to help with this project. I used the epoxy putty to seal holes from 1/16 inch to 1/4 inch, then sealed the inside of the tank.
After, I used my hvlp sprayer to apply the Rustseal to the outside of the tank and the straps. My tank came out better than new!! I filled the tank with gas last night, not one problem, NO leaks!!
Your KBS products have far exceeded my expectations. I would have been happy just getting the '38 back on the road. But it actually looks great, like show quality. I want to eventually do a complete restoration and will for certain use KBS products wherever I can.
I have try POR15 and I have found the quality and finished appearance of KBS to be far superior. Thanks for a great product. I would recommend KBS to anyone.
^ Top
John in Lake Havasu City, Az. says .. 8/30/2008
Hi, I just finished cleaning and sealing a tank off of a 1988 Honda Shadow. It was so rusty, I thought I would have to replace the tank. After searching unsuccessfully for another tank, I deceided to try you sealer kit. I had good luck with it last year on a Puch tank in frame.
It worked great. That sealing materiel is is some hard stuff. I left the supplied brush in the empty can and let it set. I still can't pull it out. Good stuff..Thanks for a great product.
^ Top
Patrick C. says .. 7/17/2008
Works as advertised? Works better than advertised. A flexible impervious coating that is second to none. (Well, maybe teflon) I have a 1980 BMW that I was mulling over selling, restoring or throwing it in the s@%# can. Who wants to buy a new tank? The rest of the bike is excellent but the tank was full of rust chips so bad it was unusable.
I carefully followed all directions to a "T" and it came out absolutely beautiful. If you are not blind and/or stupid, you can do this too.
^ Top
More results:  Previous Page  [1]... 3 4 5 [6] 7 8  Next Page
