Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > KBS Direction Pages > Xtreme Temperature Coating Directions
Xtreme Temperature Coating Directions pdf Version
Printer Friendly
Order Xtreme Temperature Coating
Xtreme Temperature Coating On The KBS Support Forum
Xtreme Temperature Coating On The KBS HelpDesk
To achieve expert results, please take the time to carefully read and understand the following directions before you begin your restoration project. These directions are meant to be general guidelines only and do not cover every application or environmental situation. If you have remaining questions or concerns, please call us toll-free (1-877-548-9323) for technical assistance.
DESCRIPTION:
KBS Xtreme Temperature Coating is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500°F (260°C) to 1500°F (812°C). With proper preparation, KBS Xtreme Temperature Coating provides outstanding adhesion, film integrity, corrosion, weathering and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off!
RECOMMENDED USES:
Engines, Manifolds, Headers, Mufflers • Furnaces, Kilns, Ovens, Stoves • Compressors, Turbines • Stoves (wood, coal, pellet, gas, etc.) • Fireplace hoods, screens, & accessories
FEATURES:
Withstands continuous temperature of up to 1500°F (812°C) • Outstanding heat and weathering resistance • Will not peel, flake, or chalk • Long Lasting • Dries for handling in 15 mins • Once heat cured, is resistant to scratching & marring
NOT RECOMMENDED FOR:
Parts that will be immersed • Direct contact with open flame • Cooking surfaces
SURFACE PREPARATION:
Steel surface to be primed must be dry and free from dirt, oils, rust, and other contaminants. Sandblasting is the ideal surface preparation as it leaves the ideal anchor pattern for paint adhesion. After sandblasting, use clean compressed air to blow off any residual blast media. Be sure to wear surgical-type gloves when handling to keep natural body oils off the prepared surface.
If not sandblasting, prepare surface by using wire wheel, wire brushing, or abrasive sanding using 60-80 grit paper. This method will provide a surface equivalent to that provided by sandblasting and allow the desired surface profile or anchor pattern.
Wash surface with KBS AquaKlean at a 10:1 (Water/AquaKlean) ratio, rinse and let dry thoroughly, or a thorough wipe down with Acetone or Xylene is recommended to wash away residual oils. Allow surface to thoroughly dry before proceeding.
Mask off areas not to be coated & protect adjacent areas with drop cloth or newspapers.
For best results, apply when Xtreme Temperature Coating and room temperatures are between 60-80° F (16-27° C).
MIXING:
Do not open containers until ready to use. Re-disperse any settled-out pigments by stirring with a paint paddle or power mixer to a uniform consistency. Keep lid on container when not in use.
COVERAGE:
Theoretical coverage at one mil (25 microns) is 400 (Alum)/300 (All Others) sq.ft. per gallon OR 9.6 (Alum)/7.0 (All Others) sq.m. per liter. Recommended thickness of two mils (50 microns) would require two full coats. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 30% less coverage on rough surfaces. Aerosol can theoretically covers 8 sq. ft.
APPLICATION:
Ideal application temperatures of air & substrate to be coated are 50-82°F (15-28°C). KBS Xtreme Temperature Coating may be applied by conventional or HVLP spray, airless spray, brush or roller. Do not apply KBS Xtreme Temperature Coating in heavier films than specified since blistering may occur.
For maximum corrosion protection, metal surfaces should be primed with KBS Xtreme Temperature Coating Primer our silicone zinc dust heat and corrosion resistant primer (approx. 1.0 mils/25um DFT), then topcoated with one coat (1.0 mils/25um DFT) of the Xtreme Temperature Coating color of your choice.
If not using KBS Xtreme Temperature Coating Primer, apply two coats (1.0 mils/25um DFT each) of KBS Xtreme Temperature Coating allowing at least 8 hours between coats and allow the second coat to dry at least 8 hrs before subjecting surface to any heat. The number of coats of KBS Xtreme Temperature Coating needed depends upon service conditions of equipment.
SPRAY APPLICATION:
FOLLOW ALL CAUTION & WARNING NOTICES WHEN SPRAYING. ALWAYS WEAR AN AIR SUPPLIED RESPIRATOR: NIOSH/MSHA approved organic vapor particulate respirator. Spray pressure of 35-45 psi (250-330kpa) for siphon/pot guns and 25-35psi (170-250kpa) for gravity/top container guns. Thinning is not generally required but if needed 5%-10% is normally adequate. Use KBS #1 Thinner only which is a slow evaporating solvent. Do not reduce Xtreme Temperature Coating with lacquer thinner. Also remember to clean your spray gun immediately after using Xtreme Temperature Coating.
BRUSH APPLICATION:
FOR BEST RESULTS, use natural bristle or foam/sponge brushes. Apply thin covering coats (1.5-2.0 mils/35-50um wet film thickness). Do not flood surface with coating. As with all KBS Products, multiple thin coats is always the best practice.
Brush out thoroughly, maintaining a continuous wet edge and uniform appearing paint film. Do not over work brushing while attempting to eliminate brush marks. Whatever brush marks don't flow out during air dry process will flow out during initial heat curing. Do however avoid runs or drips.
Allow first coat to air dry at least 8 hrs before applying recommended second coat. Allow second coat to cure at least 8 hrs before subjecting to temperature curing.
AEROSOL SPRAY APPLICATION:
For best results, apply when spray can and room temperatures are between 60-80° F (16-27° C). Shake can vigorously for one minute after mixing ball rattles freely & periodically during use to ensure proper mixing and to prevent spray head from clogging. Repeat shaking frequently during use.
Hold aerosol can 12-15 inches from surface and apply using steady, even strokes. Apply a minimum of two light coats, avoiding drips & runs. Allow 15-30 minutes drying time between coats. Heavy applications can lead to reduced coating life/adhesion.
Clean spray head immediately after use by turning can upside down and spraying until no more paint appears. If clogging occurs, remove spray head and clean with a fine wire. Replace carefully, pointing can and spray head away from you.
Allow painted surface to dry a minimum of 8 hrs before subjecting to high heat.
TEMPERATURE CURING:
After proper dry time, coating will be dry to the touch and can be handled using care, but resins will not reach full hardness until heated to approx. 350° F (176° C). For headers or manifolds, this can be done in an oven, BBQ, or by mounting back on engine and run to normal operating temperature.
NOTE: Coating can emit potentially harmful vapors during the first few heat/cool cycles. Allow for full and proper ventilation during initial heat curing. Avoid excessive heat during this initial "break-in" period, as the resins need to be tempered into the substrate to provide proper adhesion.
THINNING:
KBS Xtreme Temperature Coating can be thinned up to 5% (20 parts paint/1 part thinner). Only thin using KBS #1 Thinner. Note: Use of other thinners not approved by KBS may hinder product performance and void product guarantee.
DRY TIME:
70°F (21°C) 50% RH. KBS Xtreme Temperature Coating will air dry tack and thumb print free within 1/2-1 hour. Allow at least 8 hours dry time between coats. Allow at least 8 hour solvent flash off period before heat curing or placing into service.
Optimum film properties require a heat cure of 350°F (176°C) for 20 minutes. Equipment such as exhaust manifolds & headers protected with the KBS Xtreme Temperature Coating in the air-dried state will heat cure when placed into service.
CLEAN UP:
Thoroughly flush spray equipment and hoses immediately after use with KBS #1 Thinner or lacquer thinner. Dismantle spray equipment and clean parts, brushes or rollers.
STORAGE:
Store in a cool, dry place with temperatures between 50°F and 100°F (10°C and 38°C). Keep container closed when not in use.
QUESTIONS & TIPS:
Q. Do I need to sandblast?
A. No, while a sandblasted surface is ideal for cleaning & providing an ideal anchor pattern or coating adhesion, wire brushing and/or abrasive sanding with 60-80 grit sandpaper will work well also.
Q. How many coats of Xtreme Temperature Coating do I really need?
A. We recommend a minimum of two coats of Xtreme Temperature Coating or one coat of Xtreme Temperature Coating Primer & one coat of Xtreme Temperature Coating (color of your choice). Additional coats of Xtreme Temperature Coating will just add to the durability and corrosion protection.
Q. Do I need to heat the surface before painting?
A. No, the surface should be at room temperature 50-82°F(15-28°C) during application. Do not apply to a hot surface.
Q. Do I need to heat cure after application?
A. Yes, while the surface will dry to the touch within 1/2-1 hour, the coating will not reach it's full cure until it reaches approximately 350°F (176°C).
Q. Do I need to temperature cure between coats?
A. No, heat curing between coats is not necessary. In additon, heat curing will not hinder subsequent coats of Xtreme Temperature Coating.
Q. If I temperature cured my piece already, can I apply another coat of Xtreme Temperature Coating?
A. Heat curing will not hinder subsequent coats of Xtreme Temperature Coating.
TECHNICAL DATA:
Characteritics Jet Black, Cast Iron Grey, Charcoal Metallic,
Pure White,
Off-White & Flame Blue
Aluminum
Generic Type Silicone Silicone
Color Black, Grey, Blue, White & Ivory Silver
Temperature resistance
Continuous
Intermittent
1500°F (815°C)
1600°F (871°C)
1500°F (815°C)
1600°F (871°C)
Percent (%) Solids by volume 18 (varies with color) 25
Viscosity 300-450 cps (varies with color) 300-450 cps
Dry film thickness per coat 0.75 - 1.0 mils (19 - 25 microns) 1.5 - 2.0 mils (37 - 50 microns)
Wet film thickness per coat 4- 5 mils (100 - 125 microns) 6.0 - 8.0 mils (150 - 200 microns)
Theoretical coverage 289 mil. sq. ft. (27 sq. m. @ 25 microns) 401 mil. sq. ft. per gallon
Drying time @ 50% RH
To Touch
To Handle
To Recoat
To Ship
50°F (10°C)         70°F (21°C)
50 Minutes          25 minutes
1 Hour                30 minutes
10 hours                7 hours
42 hours              20 hours
1 hour                 30 minutes
1 hour 15 mins       40 minutes
12 hours                  8 hours
48 hours                  24 hours
Full cure @ 350°F (177°C)* 30 minutes 30 minutes
Weight per gallon 8.8 lb. (4.1 kg.) 9.6 lb. (4.3 kg.)
Flash point 45°F (7°C) 45°F (7°C)
Pot life N/A N/A
Shelf life 1 year 1 year
Volatile organic compounds 5.85 lb./gal. (696 g./l.) 5.3 lb./gal. (630 g./l.)
* See Dry Time section
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
