Xtreme Temperature Coating Silicon Zinc Primer prevents corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. Xtreme Temperature Coating Silicon Zinc Primer functions much like galvanizing as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating.
Topcoat with KBS Xtreme Temperature Coating paint or KBS Motor Coater Engine Enamel to prevent rusting and streaking of steel in severe weathering exposures. Xtreme Temperature Coating Silicon Zinc Primer can be used alone as a finish paint. KBS Xtreme Temperature Coating Primer withstands temps in excess of 1200°F (648°C).
Xtreme Temperature Coating Silicon Zinc Primer is free of fluorocarbons, lead, and chromates. Xtreme Temperature Coating Silicon Zinc Primer is Grey in color.
- One 12oz. Aerosoal XTC Primer covers 25 sq. ft. with one coat.
- One Quart of XTC Primer covers 133 sq. ft. with one coat.
- One Gallon of XTC Primer covers 530 sq. ft. with one coat.
