AQUAKLEAN SHOULD ALWAYS BE DILUTED WITH WATER.
NOTE: The warmer the water used, the more effective and powerful the cleaning action of AquaKlean. Effective dilution rates will vary according to the type and degree of contaminants as well as surface materials. AquaKlean may be used in power washing equipment.
RECOMMENDED WATER DILUTION RATIOS:
Heavily Soiled Surfaces (Diesel engines, fuel tanks)
1:1 with water |
Moderately Soiled Surfaces (Pre-paint cleaning) |
1:5 with water |
Lightly Soiled Surfaces (Truck road film) |
1:10 with water |
PROTECTIVE RUBBER GLOVES AND SAFETY GLASSES SHOULD BE WORN AT ALL TIMES WHEN USING THIS PRODUCT.
For general purpose cleaning, apply liberally and wash surface for 5-10 minutes. For heavy-duty cleaning, extended soaking times up to 24 hours or more may be necessary. Use a bristle brush or scouring pad to expedite the cleaning of heavily soiled surfaces. Retreat surface as necessary until clean.
DO NOT ALLOW AQUAKLEAN TO DRY before rinsing. Rinse thoroughly with water after cleaning and let dry. NOTE: Metal surfaces cleaned with AquaKlean should always be treated with KBS RustBlast before painting to ensure proper adhesion.
NOTE: For all alloys and non-ferrous metals, application times and dilution rates should be kept to a MINIMUM due to the wide variations in these materials. |
