Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Spray Guns
Astro HVLP Mini Gravity Feed Spray Gun with 1.0 Tip! Perfect spraying tool for detail maintenance, repairs, small area, or small parts. Ideal for spraying KBS RustSeal, KBS BlackTop and KBS Fusion.
$98.95
The Astro HVLP Mini Gun features a stainless steel needle & nozzle, adjustable air/fan and fluid control, 130ml Spray Pot. This gravity fed spray gun is ideal for small touch up spraying.
The Astro HVLP Mini Gun features a slimline construction, ergonomically designed with a comfort grip. The Astro HVLP Mini Gun is also packed with new features such as anti corrosion and the new patented air cap deign with high quality workmanship. Perfect for KBS RustSeal, KBS BlackTop and KBS Fusion along with Automotive Finishes.
Features:
  • Nozzle Size: 1.0 mm.
  • Operation Pressure: 41-44psi.
  • Dimensions W x H: 4-1/4" x 9-1/2".
  • Avg. Air Consumpt.: 4cfm.
  • Air Inlet Thread NPT: 1/4".
  • Required Compressor: 1hp or above.
  • Max. Pattern at 8" Distance: 4-3/4" (120mm).
  • Air Hose I.D. Size: 4-6mm.
Click HERE for Paint Spraying Guidelines.
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Paint For Rust
Recently Viewed Items
KBS AquaKlean
KBS AquaKlean
XTC Silicone Zinc Primer
White Lightning Gloves
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
