The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 25 gallons.
+Tank Sealer Application Flow Chart
+Gold Standard Tank Sealer Directions
Click HERE to see how Howie used Gold Standard Tank Sealer to seal a gas tank.
+Tank Sealer on the KBS Support Forum
+Tank Sealer Kits on the KBS Support Forum
