Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Supplies
KBS BackBone Reinforcing Mesh
A thin pliable reinforcing fiberglass mesh that lays flat to form an invisible patch made of unbeatable strength & holding power. Easy to use. No bunching, bulging or stiff loose hairs to ruin your finish. Use in conjunction with RustSeal or NuMetal to repair holes and bridge gaps in metal, wood or fiberglass.
$6.95
Experience the difference with KBS BackBone Reinforcing Mesh, a soft, thin, flexible, reinforcing fiberglass cloth with amazing strength and holding power.
Each packet contains 1 square yard of BackBone which is specifically designed to bridge gaps and repair holes and add a layer of additional security.
Apply BackBone to metal, wood or fiberglass using KBS RustSeal for unmatched protection and coverage. Your repair will stand up like a champion!
Please Note: There is one large piece of cloth in this envelope.
Do not handle mesh with bare hands. Always wear gloves when working with BackBone.
As you cut the cloth, fibers may fly into the air. Please wear a mask while cutting BackBone.
BackBone Directions
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Paint For Rust
$114.95
Paint For Rust
KBS NuMetal - Epoxy Putty
$19.95
Recently Viewed Items
KBS AquaKlean
KBS AquaKlean
KBS All-In-One Chassis Kit
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
