Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Stop Rust Paints
KBS All-In-One Chassis Kit
$85.95
RustSeal Color:
BlackTop Color:
*Kit includes Black Lightning Gloves, Brushes and Stir Sticks.
Gloss
Black
Satin
Black
Off-White
Grey
Silver
Oxide
Red
Guardian
Green
Safety
Blue
Cat
Yellow
Galvanized
Steel
*Click on an image for a larger view. *Click HERE for more information on which color of RustSeal you should use.
*Click HERE for the unique characteristics of Galvanized Steel and to order.
RustSeal - Stop Rust
  • AquaKlean - An Industrial Strength Cleaner & Degreaser.
  • RustBlast - A Rust Remover & Zinc Phosphate Metal Prep.
  • RustSeal - A Non Porous Waterproof, Rust Preventive Sealer. Available in your choice of 10 colors.
  • BlackTop - A Superior Topcoat With Unbeatable UV Protection & Flexibility. Available in Gloss Black or OEM Satin Black.
  • #1 Thinner – Use to Thin Spray Applications and for Clean Up.
  • Brushes, Gloves, Stir Stick & Instructions - The Intangibles Needed For Every Project.
  • Will cover 50 sq. ft. - 2 Coats of RustSeal, 1 Coat of BlackTop.
  • Single component formula
  • High solids content
  • Widest array of (10) non-porous color formulas
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Quart - AquaKlean
  • Quart - RustBlast with Sprayer
  • Pint - BlackTop (either color)
  • 8oz. - #1 Thinner
  • Black Lightning Nitrile Gloves
  • Two Brushes
  • Stir Stick
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
KBS Work Gear Black Lightning Gloves
Paint For Rust
Paint For Rust
BlackTop Chassis Paint
Recently Viewed Items
KBS NuMetal - Epoxy Putty
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
