Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealers
KBS Cycle Tank Sealer Kit
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
$36.95
*Kit includes Black Lightning Gloves, a Piece of BackBone (Reinforcing Mesh), Brush and Stir Stick. Working on a Tank with a Previous Liner? Our PLUS KIT contains a Quart of Strip to quickly remove failed sealers. Go HERE for the PLUS KIT.
"I tried this product myself ... WORKED GREAT!!!!!"
Dave Stewart, Product Specialist for JP Cycles
Cycle Tank Sealer Kit Overview
The KBS Cycle Tank Sealer Kit contains everything you need to seal a tank of up to 5 gallons.
Gas Tank Sealer
Contents
  • Quart of AquaKlean
  • Quart of RustBlast
  • 8oz. of Gold Standard Tank Sealer
  • Black Lightning Gloves
  • Stir Stick
  • Detailed Instructions
Directions & Information Sheets
Cycle Tank Sealer Kit Features
  • Gold Standard Tank Sealer can withstand temperatures of up to 500° F.
  • Non-flammable
  • Environmentally safe
Cycle Tank Sealer Kit How To
Applications
steel, aluminum & fiberglass fuel tanks • diesel tanks • oil tanks • utility tanks • non-potable water tanks
Technical Support
Search The KBS Support Forum
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Cycle Tank Sealer PLUS Kit
$44.95
Paint For Rust
$41.95
Paint For Rust
Auto Fuel Tank Sealer Kit
$62.95
Recently Viewed Items
KBS All-In-One Chassis Kit
BlackTop Chassis Paint
KBS AquaKlean
KBS AquaKlean
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
