Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealers
Cycle Tank Sealer PLUS Kit
Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
$44.95
*Kit includes Black Lightning Gloves, a Piece of BackBone (Reinforcing Mesh), Brush and Stir Stick.
Cycle Tank Sealer Kit - Plus Stripper
The KBS Cycle Tank Sealer PLUS Kit contains everything you need to strip and seal a tank of up to 5 gallons.
  • Quart of Strip
  • Quart of AquaKlean
  • Quart of RustBlast
  • 8oz. of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
Tank Sealer Application Flow Chart
Gold Standard Tank Sealer Directions
Tank Sealer Chemical Resistance
Tank Sealer Tech Data Sheet
  • Strips previous coatings or liners
  • Gold Standard Tank Sealer can withstand temperatures of up to 500° F.
  • Non-flammable
  • Environmentally safe
Click HERE to see how Howie used Gold Standard Tank Sealer to seal a gas tank.
steel, aluminum & fiberglass fuel tanks • diesel tanks • oil tanks • utility tanks • non-potable water tanks
Tank Sealer on the KBS Support Forum
Tank Sealer Kits on the KBS Support Forum
Search The KBS Support Forum
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
$41.95
Paint For Rust
Tank Sealer Kit for 25-50 Gallon Tanks
$114.80
Paint For Rust
Auto Fuel Tank Sealer Kit
$62.95
Recently Viewed Items
KBS Cycle Tank Sealer Kit
KBS All-In-One Chassis Kit
BlackTop Chassis Paint
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
