NuMetal Epoxy Putty is an easy-to-use, two-part putty that mixes like clay but hardens like steel! NuMetal bonds, seals, fills, insulates, anchors, caulks and waterproofs. It cures without shrinking or sagging and can be drilled, tapped, sanded, primed and painted. NuMetal will not only stick to damp surfaces, but it will cure underwater!
Our Black NuMetal is ideal for automotive applications ... if the surface coating sustains damage, the black epoxy putty beneath remains unseen! Use White NuMetal for marine applications and boat repairs. Satisfaction guaranteed!
Pool & Spa: tile & grout • PVC & ABS pipe • sealing underground pipe fittings • cracked pump housing • skimmers • pool decks • concrete decks • cracked timer & control boxes • filter grids & screens • broken control handles & knobs • patching cracks in pool gunite • concrete & plastered walls • bottoms & steps • broken pool tools • cracked coping • mounting hardware & ladders • hand rails • diving boards • water fittings • gaskets
Marine Yacht & Boat: scrapes • dents • chips • holes • leaks • breaks on fiberglass, wood, metal & plastics • broken fuel lines • broken or cracked water lines & tanks • bonds loose carpet • waste system repairs for tanks & lines • emergency repair to engine fuel & water lines
RV & Auto: PVC & ABS pipe • water lines, fittings & tanks • broken fixtures • chipped grills • handles • emergency repair engine fuel & coolant lines • gaskets • plumbing cracks & leaks • furniture, wood, fiberglass, ceramic & plastic • tubs, toilets, sinks, tiles & caulking • emergency repairs for radiator & cracked engine blocks • battery terminals & cases
Home: furniture • water lines • PVC & ABS pipe • dents, scrapes, chips & nicks • cast iron, brick, concrete, tile, ceramics, stone, glass, pottery, wood, plastic & ceramic • sprinkling line repair • sealing underground connections & elbows • cracks & leaks in plumbing fixtures • tubs, toilets, sinks, tiles & caulking • broken filling on appliances • air conditioning & refrigeration coils • attaching golf club shafts to golf club heads
Industrial: leaking drum repair • water & air lines • HVAC coolant & refrigeration lines • plumbing fixtures
