Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Stop Rust Paints
KBS Frame Coater Kit
Our quart size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. Top Quality protection at a tremendous value! Detailed instructions included.
$57.95
Color:
*Kit includes Black Lightning Gloves, Brushes and Stir Stick.
Gloss
Black
Satin
Black
Off-White
Grey
Silver
Oxide
Red
Guardian
Green
Safety
Blue
Cat
Yellow
Galvanized
Steel
*Click on an image for a larger view. *Click HERE for more information on which color of RustSeal you should use.
*Click HERE for the unique characteristics of Galvanized Steel and to order.
RustSeal - Stop Rust - Paint Over Rust
The KBS Frame Coater Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 50 square foot area.
KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coatings), KBS AquaKlean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
RustSeal chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture.
RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products.
  • Single component formula
  • High solids content
  • Widest array of (10) non-porous color formulas
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Quart - AquaKlean
  • Quart - RustBlast
  • Black Lightning Gloves
  • Two Brushes
  • Stir Stick
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Paint For Rust
KBS All-In-One Chassis Kit
$85.95
Paint For Rust
$114.95
Recently Viewed Items
Cycle Tank Sealer PLUS Kit
KBS Cycle Tank Sealer Kit
BlackTop Chassis Paint
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
