Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > How Much Do I Need - Tank Sealer
Which Tank Sealer Kit or How Much Do I Need?
Use this Guide to help determine which Tank Sealer Kit you should order or how much AquaKlean, RustBlast and Gold Standard Tank Sealer you should order. This Guide is for most tanks including Gas Tanks, Diesel Tanks, Fiberglass Tanks, Tractor Gas Tanks, Oil Tanks, Utility Tanks and Non-potable Water Tanks.. Gold Standard may be used on steel, aluminum, and fiberglass tanks. Please keep in mind that these are just guidelines. Coverage will vary based on application, condition of tank, substrate of tank, and other factors.
Tank Size (Gallons) What We Suggest
5 or less
Cycle Tank Sealer *PLUS* Kit
(If you have a Previous Coating)
5 - 12
Large Cycle Tank Sealer
*PLUS* Kit
12-25
Auto Fuel Tank Sealer Kit
25-50
Tank Sealer Kit for 25-50 Gallon Tank
50-100
1 Gallon AquaKlean
1 Gallon RustBlast
1 Gallon Gold Standard Tank Sealer
100-125
2 Gallons AquaKlean
2 Gallons RustBlast
1 Quart Gold Standard Tank Sealer
125-150
2 Gallons AquaKlean
2 Gallons RustBlast
2 Quart Gold Standard Tank Sealer
150-200
2 Gallons AquaKlean
2 Gallons RustBlast
2 Gallons Gold Standard Tank Sealer
**Larger than 200? Please give us a call (1-877-548-9323) and we will
help you order the correct quantity.
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
