Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > KBS Direction Pages > KBS Strip Directions
Strip Instructions pdf Version - Printer Friendly
KBS RustSeal - Stop Rust
Order Strip
Order Cycle Tank Sealer PLUS Kit
Order Large Cycle Tank Sealer PLUS Kit
DIRECTIONS:
Carefully pour Strip into spray bottle (use ONLY in special sprayer provided) and adjust the sprayer nozzle for an even spray pattern.
Spray an even, generous layer of Strip and allow it to work approx. 15 minutes. (heavy coatings may require spraying again to completely loosen surface finish.)
Gently scrape off blistered finish with putty knife and place in metal container. A small stiff scrub brush can be used on corners or tougher areas.
After the majority (90%) of the finish is removed, spray again. After 5–10 minutes, wash with #2 steel-wool or stripping pad dipped in water or solvent (paint thinner, alcohol, mineral spirits).
Wipe completely clean with a rag or paper towel. If not cleaned completely steel wool may leave residue which can cause spots and streaking. Pour unused remover back into container and rinse out both bottle and sprayer with water. Clean up rags, paper and waste promptly. Allow solvents to evaporate, then dispose of in metal container in accordance with local, state and federal regulations.
TANK STRIPPING:
Carefully Pour entire contents of can into tank and slowly rotate and roll tank until all sides are evenly coated. Patiently work with it for a minimum of 20 minutes but no longer than 1 hour, periodically checking inside.
If an area needs extra attention, prop the tank so that the excess collects on that area. Continue this until the majority of the remaining sealer is loosened and/or removed.
After Strip has been allowed to work, pour out & capture into an appropriate metal container for possible reuse. Rinse tank thoroughly with water. If any part of the sealer still remains, repeat steps until old sealant is removed.
Rinse tank with water and allow to dry COMPLETELY before using appropriate prep products and Gold Standard Tank Sealer.
ADDITIONAL INFORMATION:
Harmful to: Tile, Linoleum, Asphalt, Plastics, Rubber and Synthetics.
May soften fiberglass.
Strip should be used within six months of opening or disposed of properly to avoid can deterioration.
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
