Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > All KBS Coatings Products
Strip - Paint Remover / Stripper
Our aircraft strength paint remover sprays as a semi gel coat for fast and easy coverage. This results in an even, unbroken film which seals and allows deep penetration through multiple layers of paint. Due to it’s semi gel state, Strip will cling to vertical surfaces with minimal run or sag, while offering low-odor technology. Try some today and see why our customers call KBS Strip "...the best stripper I've ever used"!
Quart - $14.95  |  Gallon - $34.95
$0.00
Size:
*Quarts & Gallons include Chemical Resistant Bottle and Sprayer.
KBS Strip is a heavy-duty paint, stain & varnish remover developed for use on wood, metal & masonry surfaces. This penetrating semi-gel formula clings to vertical surfaces like magic & removes even your toughest finishes fast & easy!
The spray bottle applicator promotes even sealing coverage & deep penetrating power for removing stubborn layers of finishes even in hard to reach places!
Another advantage of Strip is that it contains an evaporation sealant which drastically lowers the amount of odor. Strip can be easily washed off with water or solvent without leaving a residue.
Lead-based paints • Polyurethanes • Lacquers • Shellacs • Marine Finishes • Tile & Carpet Adhesives Epoxies • Latex • Stains • Varnishes • Acrylics • Gas Tank Coatings • Most Any Finish ...
KBS Strip - Paint Stripper
  • Gels when sprayed – clings to vertical surfaces
  • Very low odor – contains evaporation sealant
  • Will not raise wood grain or harm patina
  • Safe for all woods and metals – leaves no residue
Furniture • Woodwork • Machinery • Masonry Antiques • Floors • Cars & Boats • Graffiti • OEM Finishes • Cars Bodies & Frames • Fuel Tanks • Floors
  • Click HERE for KBS Strip Information and Intructions.
Search for Answers to Your Questions
  • Click HERE for KBS Strip on the KBS Support Forum.
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Paint For Rust
KBS Cycle Tank Sealer Kit
$36.95
Paint For Rust
$41.95
Recently Viewed Items
KBS Paint Spout
KBS Paint Spout
KBS Instructional DVD - Vol. 1
HVLP Spray Gun :: 1.4 Tip
Gift Certificate
Gift Certificate
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
