Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealers
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
$41.95
*Kit includes Black Lightning Gloves, a Piece of BackBone (Reinforcing Mesh), Brush and Stir Stick. Working on a Tank with a Previous Liner? Our PLUS KIT contains a Quart of Strip to quickly remove failed sealers. Go HERE for the PLUS KIT.
"I tried this product myself ... WORKED GREAT!!!!!"
Dave Stewart, Product Specialist for JP Cycles
Overview
The KBS Large Cycle Tank Sealer Kit contains everything you need to seal a tank of up to 12 gallons.
Contents
  • Quart of AquaKlean
  • Quart of RustBlast
  • Pint of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
Directions & Information Pages
Tank Sealer Application Flow Chart
Gold Standard Tank Sealer Directions
Tank Sealer Chemical Resistance
Tank Sealer Tech Data Sheet
Features
  • Gold Standard Tank Sealer can withstand temperatures of up to 500° F.
  • Non-flammable
  • Environmentally safe
How-To's
Click HERE to see how Howie used Gold Standard Tank Sealer to seal a gas tank.
Applications
Tech Support
Tank Sealer on the KBS Support Forum
Tank Sealer Kits on the KBS Support Forum
Search The KBS Support Forum
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
KBS Cycle Tank Sealer Kit
$36.95
Paint For Rust
$49.95
Paint For Rust
Auto Fuel Tank Sealer Kit
$62.95
Recently Viewed Items
KBS Fusion - Self-Etching Primer
KBS Frame Coater Kit
KBS BackBone Reinforcing Mesh
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
