Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Restoration Kits
KBS Frame Coater Kit
$57.95
Our quart size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. Top Quality protection at a tremendous value! Detailed instructions included.
Motorcycle Frame Coater Kit
$45.95
This complete Motorcycle Frame Paint Kit takes our popular System Sampler Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes 8oz of BlackTop topcoat for a permanent final finish on your bike frame which withstands dulling and fading caused by prolonged sunlight exposure.
Auto Fuel Tank Sealer Kit
$62.95
The KBS Auto Fuel Tank Sealer Kit contains everything you need to clean, prep & permanently seal up to 25 gallon tank. Detailed instructions included. Satisfaction guaranteed!
Cycle Tank Sealer PLUS Kit
$44.95
Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
$49.95
Our "PLUS" Kit contains everything found in our LARGE CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
Motor Coater Engine Painting Kit
$49.95
As every painting professional knows, the keys to any long lasting paint job are good surface prep and the use of quality materials. Our complete KBS Motor Coater Kit was developed to guarantee just that! Your engine will be a show stopper at this DIY price...too bad it's kept under the hood!
KBS System Sampler Kit
$18.95
Everything you need to get started & try out our complete KBS system! A full 1/2 pint of RustSeal will cover an approx. 12 sq. ft. area with 2 coats. Experience the quality & durability for yourself. A KBS best buy! Our complete system in one package!
$123.95
KBS 4PAK :: Convenience Quart
$50.95
$114.95
A terrific solution that fits your budget! Here’s a PROFESSIONAL restoration kit that will save you $$$ versus the cost of replacement. Restore your floor pan, trunk, or pickup truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
KBS All-In-One Chassis Kit
$85.95
KBS Cycle Tank Sealer Kit
$36.95
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
$41.95
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
Tank Sealer Kit for 25-50 Gallon Tanks
$114.80
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Detailed instructions included. Satisfaction guaranteed!
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
