Stop Rust Paints
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > KBS Direction Pages > RustBlast Directions
RustSeal Instructions pdf Version - Printer Friendly
KBS Coatings :: RustBlast
Order RustBlast
Knowledgebase
RustBlast on the
KBS Support Forum
  1. Surface to be treated should be free of dirt, oil, grease and other contaminants. The cleaner the surface, the more effective RustBlast will work.
  2. Scrape off any loose rust, mill scale, paint, etc. and clean with a WATER-BASED cleaner/degreaser. FOR BEST RESULTS, Use KBS AquaKlean. Avoid any solvent-based cleaners as they can leave an invisible residue.
  3. Liberally apply RustBlast FULL-STRENGTH to a DRY surface using a spray bottle, brush, roller, or backpack sprayer for larger applications.
  4. Re-apply often and as needed to keep the surface wet for a minimum of 10 minutes for smooth or lightly rusted surfaces, 20-40 minutes for moderately rusted surfaces and 1-2 hours for  heavily rusted or corroded surfaces. DO NOT allow surface to dry.
  5. After treatment, rinse thoroughly with water and then allow surface to dry completely.
  6. For removal of light corrosion or etching of non-ferrous metals (such as aluminium, brass, copper), prepare surface as above and apply RustBlast for 10-20 minutes then rinse thoroughly with water and allow surface to dry completely.
PROTECTIVE GLOVES AND EYEWEAR SHOULD BE WORN AT ALL TIMES WHEN USING THIS PRODUCT.
NOTE: Once dry, RustBlast may leave a slight powder residue which is the zinc phosphate coating. Items treated with RustBlast can remain uncoated for up to 30 days depending on environmental conditions. Ideal working temperature 55-80˚F (13-27˚C).
QUESTIONS & ANSWERS
1) Why is there a white powdery substance left over after I rinse off the RustBlast?
The slight white powdery residue is zinc phosphate and RustBlast leaves that behind because it aids in adhesion of coatings such as RustSeal.
2) Can I use RustBlast when applying paints other then KBS RustSeal?
Yes.  RustBlast works well as a metal prep and etch for most paints.
3) Can I use RustBlast to remove rust from equipment and tools?
Yes. Soak the tool or equipment for 30 minutes to 24 hours and rinse it off with water using a scotch brite pad.  You will be left with rust free tools and equipment.
4) Do I really have to rinse off the RustBlast with water?
Yes.  It is important to rinse before the RustBlast dries to avoid a heavy layer of zinc phosphate.
KBS Rust Blast
RUSTBLAST INSTRUCTIONAL VIDEOS
RustBlast - Metal Etch - Rust Remover
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
