We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability.
The Galvanized Steel color can be used in all the same applications as our original RustSeal colors, but is particularly suited for industrial applications where a rapid build of a rust protective coating is needed to smooth and level rough surfaces, without gassing or sagging.
The RustSeal Galvanized Steel Advantage is that it is 3 products in 1 ... a permanent rust preventive coating, a high build primer, and a UV enhanced topcoat!
Use Galvanized Steel in conjunction with AquaKlean & RustBlast for the most complete rust prevention system available today!
- Steel roofs
- Metal fencing & posts
- Brake Calipers
- Steam pipes & pipeline repairs
- Factory parts & equipment
- To Seal fuel or water tanks
- General steel fabrication
- Welded metals
- Steel construction beams
- All other described RustSeal applications
- Ready-to-use single component formula
- High solids content (75%)
- Superb coverage w/high build, filling & leveling properties
- Superior toughness & durability
- Uniquely flexible - expands & contracts w/ temp changes
- Resistant to fuels & most chemicals
- Withstands temps up to 600° F (312°C)
- Fast moisture cure rate for easier re-coat - rock hard finish in 24 hrs.
- Self-leveling - brush, roll or spray
- Galvanized-look finish
- Can be top coated
- Enhanced UV stability
