Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > KBS Direction Pages > RustSeal - Which Color Should I Use
KBS RustSeal :: Stop Rust
KBS RUSTSEAL
WHICH COLOR SHOULD I USE?
Question & Answer with KBS
Q- I like KBS Coatings’ selection of colors but do colors require porous pigments which will let moisture through the coating?
A- A basic understanding of paint chemistry might help. Paint is simply a combination of resins and pigments. Porosity or the lack thereof is determined by the proper choice of resins. Pigments, which are fully encapsulated by these resins, simply provide color. In other words, pigments don’t determine porosity and resins don’t determine color. Some pigments are indeed porous; in fact black (carbon) is most porous of all. Yet when this extremely porous carbon pigment is encapsulated within the correct resins, the result is a non-porous coating. This obviously holds true for less porous pigments as well.
KBS RustSeal :: Gloss Black
GLOSS BLACK: A strikingly rich black finish with a long lasting wet shine! A popular choice used in all automotive restoration applications including frames & chassis.
KBS RustSeal :: Satin Black
SATIN BLACK: A rich vibrant black coating that has a low luster uniform sheen which compares to OEM finishes! A perfect application used for those wanting an "original look" of a rock hard chassis semi-gloss finish.
KBS RustSeal :: Grey
GREY: A medium grey colored coating that cures to a smooth diamond hard finish! Ideal for sealing & protecting steel, concrete, cinder blocks, warehouse floors, plywood and more!
KBS RustSeal :: Off White
OFF-WHITE: The toughest white metal primer you’ll ever use! Perfect color associated primer choice for all light colored topcoats.
Industrial Colors
These six industrial colors are our most popular version of RustSeal. All six of them contain high concentrations of solidifying metal flake and micronised iron oxide for extreme abrasion, corrision and impact performance.
KBS RustSeal :: Silver
GALVANIZED STEEL: We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability. Go HERE for more information on the unique characteristics of RustSeal Galvanized Steel.
KBS RustSeal :: Safety Blue
SAFETY BLUE: A full spec industrial safety blue with micronized corrosion barrier pigments in a brilliant safety blue color. Industrial equipment maintenance will never be the same!
KBS RustSeal :: Cat Yellow
CAT YELLOW: A full spec industrial yellow with micronized corrosion barrier pigments in a color well recognized on any work site as Cat Yellow. Heavy vehicle maintenance will never be the same!
SILVER: A rock hard silver metallic finish made for superior workplace protection. A perfect coating that can be used for reproducing the look & appearance of "bare steel!"
KBS RustSeal :: Oxide Red
OXIDE RED: A deep glossy red coating with high hide & coverage properties required for use in many types of industrial applications. A superior performance coating that will significantly reduce the maintenance costs of rust & corrosion in the workplace!
KBS RustSeal :: Green
GUARDIAN GREEN: A rich glossy green coating enhanced with high levels of micronized corrosion barrier pigments used for their high hide & coverage abilities. An outstanding maintenance finish that won’t crack, peel or blister!
<< Go Back RustSeal More Info >>
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
