Experienced users know that moisture cannot be present when applying KBS Coatings (RustSeal, BlackTop, Fusion) ... and even though your spraying system may have moisture traps and filters, condensation may occur in the hose downstream and ruin your paint job.
This great filter will absorb up to one (1) fluid ounce of moisture and insure a perfectly dry system from start to finish every time. It absorbs oil aerosols, condensed moisture, and contaminants as small as 0.01 microns. It attaches directly to the air inlet of your spray gun and, as air passes between the filter's compressed layers, particles and moisture are trapped.
This incredible filtration is accomplished at a true 30 CFM to the spray gun, with minimal pressure drop at the optimum flow rate. This disposable Spray Gun Filter is the answer to the painter's worst nightmare - FISHEYE! But now, with the introduction of High Volume, Low Pressure (HVLP) spray guns using shop air, comes even more critical requirements for clean, dry, oil free air supplying the paint gun.
Designed to remove the smallest contaminant particle, oil-aerosol or drop of moisture to supply clean, dry, oil free air to your spray gun. Users report reduced paint defects, resulting in increased productivity with the ultimate final finishes. |
