KBS RustSeal is a superior one part, completely non-porous, ready-to-use, high-solid content, rust preventive coating, that is actually strengthened by exposure to moisture. It is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch. These exceptional properties make RustSeal specifically formulated to prevent corrosion and stop rust. RustSeal completely seals metal surfaces, blocking all the pores and preventing penetration of moisture, oxygen, and water vapor. Available in Gloss Black, Satin (OEM) Black, Silver, Grey, Oxide Red, Guardian Green, Safety Blue, Galvanized Steel & Cat Yellow. Try some today...you'll be amazed!
- CAN BE APPLIED DIRECTLY OVER RUST!
- SEALS & ENCAPSULATES RUST AND POROUS SURFACES
- APPLY BY BRUSH, ROLLER, OR SPRAY.
- SUPER STRONG AND FLEXIBLE - HAMMER TOUGH!
- HIGHLY RESISTANT TO MOST CHEMICALS
- MODERATE UV STABILITY, UNLIKE OTHERS WHICH CAN CHALK WITHIN WEEKS
- COMPATIBLE WITH ALL PAINT SYSTEMS
- ALL COLORS ARE COMPLETELY NON-POROUS
Introducing our newest RustSeal color ... We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability. The Galvanized Steel color can be used in all the same applications as our original RustSeal colors, but is particularly suited for industrial applications where a rapid build of a rust protective coating is needed to smooth and level rough surfaces, without gassing or sagging. The RustSeal Galvanize Steel Advantage is that it is 3 products in 1 ... a permanent rust preventive coating, a high build primer, and a UV enhanced topcoat! Use Galvanized steel in conjunction with AquaKlean & RustBlast for the most complete rust prevention system available today! +Get More Info.
