Stop Rust Paints
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Restoration Kits
KBS System Sampler Kit
You've read the reviews, now sample our complete KBS Rust Prevention System risk-free. Here's everything you need to get started! Try our AquaKlean, RustBlast, and the RustSeal color of your choice & see for yourself why we say...RUST STOPS HERE!!
$18.95
RustSeal Color:
*Kit includes Black Lightning Gloves, Brushes and Stir Stick.
Gloss
Black
Satin
Black
Off-White
Clear
Grey
Silver
Oxide
Red
Guardian
Green
Cat
Yellow
Galvanized
Steel
*Click HERE for the unique characteristics of Galvanized Steel and to order.
RustSeal - Stop Rust
  • The KBS System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 12.5 square foot area. Don't get short changed, our kit includes 8 ounces of our RustSeal coating...not just 4 ounces. Twice the surface coverage!
  • RustSeal is a paint-like substance. RustSeal acts as a total rust inhibitor and preventive.
  • It's consistency is approximately that of paint and it has very good spreadability . KBS RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
  • This non-porous, flexible coating is incredibly tough and extremely resistant to abrasion and impact. RustSeal is highly surface tolerant and capable of adhering to almost any prepared substrate
  • Single component formula
  • High solids content
  • Widest array of (10) non-porous color formulas
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Our System Sampler Kit seals 12.5 sq. ft. with two coats.
Search for Answers to Your Questions
  • 8oz. - AquaKlean
  • 8oz. - RustBlast
  • 8oz. - can of KBS RustSeal (any color)
  • Nitrile Gloves
  • Two Brushes
  • Stir Stick
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
KBS Frame Coater Kit
$57.95
Paint For Rust
KBS All-In-One Chassis Kit
$85.95
Paint For Rust
$114.95
Recently Viewed Items
KBS WorkGear - Ultralast Gloves - Comfort Series 13
KBS WorkGear - Ultralast Gloves - Comfort Series 12
Pre-Val Spray Gun
Pre-Val Spray Gun
KBS WorkGear - Ultralast Gloves - ProDuty Series 2
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
