Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > KBS Direction Pages > Gold Standard Tank Sealer Chemical Resistance Guide
Material
Spill, splash or incidental / occasional contact
Periodic contact
(<1 hour per day)
Immersion, constant contact
or condensation vapours
Acetic Acid 5%
3
3
3
Acetic Acid 10%
3
3
3
Acetone
3
3
3
Ammonium Hydroxide 1%
3
3
3
Ammonium Hydroxide 5%
3
3
3
Benzene
3
3
3
Bleach
3
3
3
Brake Fluid
3
3
NR
Chromic Acid 20%
3
3
NR
Citric 10%
3
3
3
Coal Dust
3
3
3
Deionized Water
3
3
3
Detergent Solution Weak
3
3
3
Detergent Solution Strong
3
3
3
Diesel
3
3
3
Distilled Water
3
3
3
Ethylene Glycol (Antifreeze)
3
3
3
Ethanol
3
3
3
Ferric Chloride 2%
3
3
3
Ferric Sulfate 10%
3
3
3
Grape Juice
3
3
3
Heptane
3
3
3
Hexane
3
3
3
Hydraulic Fluid
3
3
3
Hydrochloric Acid 10%
3
3
3*
Hydrochloric Acid 20%
3
3
NR
Hydrogen Peroxide Solution 3%
3
3
3
Hydrogen Sulfade (sewer gas)
3
3
3
Kerosene
3
3
3
Lactic Acid 5%
3
3
3
Lactic Acid 10%
3
3
3
Methanol
3
3
3
Methylene Chloride
NR
NR
NR
Methyl-Ethyl Ketone
3
3
NR
Mineral Spirits
3
3
3
Nitric Acid 5%
3
3
3
Nitric Acid 10%
3
3
3*
Nitric Acid 30%
3
3
NR
Oil (Automotive)
3
3
3
Oil (Vegetable)
3
3
3
Oleic Acid
3
3
3
Petrol (Automotive Fuel)
3
3
3
Petrol  (Aviation Fuel)
3
3
3
Jet Fuel
3
3
3
Phenol Solution
3
3
3
Phosphoric Acid 10%
3
3
3
Phosphoric Acid 70%
3
3
NR
Potassium Hydroxide
3
3
NR
Salt Brine
3
3
3
Skydrol
3
3
3
Strong Soap Solution 4%
3
3
3
Sodium Chloride
3
3
3
Sodium Hydroxide 10%
3
3
3*
Sodium Hydroxide 50%
3
3*
NR
Sodium Hypochlorite 2%
3
3
3
Sulfuric Acid 10%
3
3
3*
Sulfuric Acid 25%
3
3*
NR
Sulfuric Acid 50%
3
3*
NR
Sulfuric Acid 95%
3
3*
NR
Toluene
3
3
3
Trichloroethane
3
3
3
Water (Distilled)
3
3
3
Xylene
3
3
3
3 = Suitable for general applications
3* = Generally suitable but some testing should be done prior to use
NR = Not Recommended
PLEASE NOTE: This Chemical Resistance Guide is a GUIDE ONLY to the general chemical resistance of Gold Standard Tank Sealer and cannot be used as a bible for all applications and conditions without prior testing. We used not less than 150um film thickness. Average temperature when applied was 20 degrees Centigrade. Common variables to be aware of include temperature; direction of the heat; any localized heating (hot spots); chemical concentration levels; different preparation techniques; chemical layering; different manufacturers specifications for the "same product"; differing substrates and varying film thickness of applied Gold Standard Tank Sealer.
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
