Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealers
Tank Sealer Kit for 25-50 Gallon Tanks
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Detailed instructions included. Satisfaction guaranteed!
$114.80
Kit Contains:
  • Gallon of AquaKlean
  • Gallon of RustBlast
  • 2 Quarts of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
The KBS Tank Sealer Kit contains everything you need to seal a tank of up to 50 gallons.
NOTE:This Kit should work for an average 25-50 gallon tank. Coverage will vary based on application, condition of tank, substrate of tank, and other factors.
  • Nitrile Gloves
  • Stir Stick
+Tank Sealer Application Flow Chart
+Gold Standard Tank Sealer Directions
+Tank Sealer Chemical Resistance
+Tank Sealer Tech Data Sheet
Search The KBS Support Forum
  • Non-flammable
  • Environmentally safe
+Click HERE to see how Howie used Gold Standard Tank Sealer to seal a gas tank.
Steel, Aluminum & Fiberglass Fuel Tanks • Oil Tanks • Utility Tanks • Diesel Tanks • Non-potable Water Tanks
+Tank Sealer on the KBS Support Forum
+Tank Sealer Kits on the KBS Support Forum
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
KBS Cycle Tank Sealer Kit
$36.95
Paint For Rust
$41.95
Paint For Rust
KBS NuMetal - Epoxy Putty
$19.95
Recently Viewed Items
KBS Gear Short Sleeve T-Shirt
KBS Dry Air Spray Gun Filter
Safety Orange Nitrile Gloves by KBS Work Gear
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
