Stop Rust Paints
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealer Kits
Tank Sealer Kits
Gas Tank Sealer Kits
Used by professionals worldwide, Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion. When used in combination with AquaKlean and RustBlast, it will form a super-tough, fuel and alcohol impervious coating, while simultaneously sealing small pinholes and weld seams. Gold Standard may be used on steel, aluminum, and fiberglass tanks. Applications include fuel tanks, diesel tanks, oil tanks, utility tanks and non-potable water tanks. It's been rated as the industry‘s NEW Gold Standard in gas tank sealers.
Auto Fuel Tank Sealer Kit
$62.95
$49.95
Our "PLUS" Kit contains everything found in our LARGE CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
$41.95
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
Cycle Tank Sealer PLUS Kit
$44.95
Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
KBS Cycle Tank Sealer Kit
$36.95
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
Tank Sealer Kit for 25-50 Gallon Tanks
$114.80
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Detailed instructions included. Satisfaction guaranteed!
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
