Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Tank Sealers
Gold Standard Fuel Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
8oz. - $12.95  |  Pint - $20.95  |  Quart - $33.95
Gallon - $98.95  |  5 Gallon Pail - $444.95
$0.00
Size:
NOTE: Gold Standard Tank Sealer is designed to be used as the 3rd Step in the KBS 3 Step System.
Our Convenient Kits can be found HERE.
KBS Coatings manufactures the most respected and trusted gas tank sealer in the industry today! Not only do we think of it as the NEW gold standard but we named it so! Gold Standard Tank Sealer is a superior, single component, ready-to-use sealer formulated for coating the inside of metal, aluminum & fiberglass tanks.
Widely recommended & easy-to-use, this single application coating cures into a tough fuel impervious seal. The entire tank including pinholes & weld seams are permanently sealed to prevent the return of rust & corrosion and clogged carburetors. Yet amazingly, this rock hard interior remains flexible to withstand vibration and the repeated expansion & contraction of the tank! Other sealers are little more than paint or adhesive-type coatings which have poor sealing abilities especially when exposed to today’s fuels. Wisely choose Gold Standard for an incredible long lasting seal! Satisfaction guaranteed!
Click HERE to determine How Much Tank Sealer to Order.
  • 8 oz. of Gold Standard Tank Sealer will seal up to a 5 Gallon Tank.
  • A Pint of Gold Standard Tank Sealer will seal up to a 12 Gallon Tank.
  • A Quart of Gold Standard Tank Sealer will seal up to a 25 Gallon Tank.
  • A Gallon of Gold Standard Tank Sealer will seal up to a 100 Gallon Tank.
  • GOLD STANDARD TANK SEALER is non-flammable and is environmentally safe.
Search for Answers to Your Questions
  • Non-flammable
  • Environmentally safe
steel, aluminum & fiberglass fuel tanks • oil tanks • diesel tanks • utility tanks • non-potable water tanks
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
KBS Cycle Tank Sealer Kit
$36.95
Paint For Rust
$41.95
Paint For Rust
Auto Fuel Tank Sealer Kit
$62.95
Recently Viewed Items
KBS NuMetal - Epoxy Putty
KBS Work Gear Black Lightning Gloves
KBS 4PAK :: Convenience Quart
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
