Used by professionals worldwide, Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion. When used in combination with AquaKlean and RustBlast, it will form a super-tough, fuel and alcohol impervious coating, while simultaneously sealing small pinholes and weld seams. Gold Standard may be used on steel, aluminum, and fiberglass tanks. Applications include fuel tanks, diesel tanks, oil tanks, utility tanks and non-potable water tanks. It's been rated as the industry‘s NEW Gold Standard in gas tank sealers.
Our "PLUS" Kit contains everything found in our LARGE CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
This great 3-Step cost savings kit designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
This great 3-Step cost savings kit is designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed!
Gold Standard Fuel Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Detailed instructions included. Satisfaction guaranteed!
KBS Tank Sealer & Gas Tank Liner Instructional Videos
