Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Spray Guns
Underseal Spray Gun & Probe
Perfect for spraying RustSeal into the inside of boxed frames, door panels, rocker panels, etc. Perfect for undercoating all of those hard-to-reach areas.
$79.95
  • Specially designed for rustproofing auto bodies.
  • Works with KBS RustSeal and most types of anti-rust coatings.
  • Complete with adjustable nozzle which can be set depending on viscosity of liquid or coating in use.
  • Used for applying KBS RustSeal to the inside of doors and panels.
  • 1/4 (F) NPT air inlet.
  • Underseal Gun
  • 750 ml (26 fl oz) plastic container
  • Flexible extension probe (36")
  • Working Pressure Range: 87 to 145 PSI
  • Air Flow Consumption: 13.5 SCFM (with standard nozzle)
  • Air Flow Consumption: 6.5 SCFM (with extension probe)
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
$98.95
Paint For Rust
Recently Viewed Items
Tank Sealer Kit for 25-50 Gallon Tanks
KBS Gear Short Sleeve T-Shirt
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
