When rebuilding or restoring an engine, protecting the internal cast surfaces is often overlooked. Raw cast iron and aluminum components can trap contaminants, absorb oil, and promote corrosion over time.
For decades, engine builders used Glyptal-style coatings to seal internal engine surfaces. Today, many builders are turning to KBS RustSeal as a modern alternative that delivers superior adhesion, chemical resistance, and long-term durability.
Why Internal Engine Surfaces Are Coated
Most engine blocks contain porous cast areas that can hold casting sand, machining debris, and moisture. These contaminants can eventually circulate through the oil system.
- Seals porous cast iron and aluminum
- Prevents internal rust formation
- Reduces sludge buildup
- Improves oil drain-back to the sump
- Promotes long-term engine cleanliness
What Is Glyptal and Why Builders Seek Alternatives
Glyptal is an insulating enamel originally designed for electric motors. Its ability to adhere to cast iron led to its widespread use in engine blocks.
However, traditional Glyptal coatings can suffer from limited chemical resistance, longer cure times, and reduced availability — leading builders to seek stronger modern solutions.
How RustSeal Can Be Used Like Glyptal
RustSeal is a moisture-cured urethane coating engineered to permanently bond to metal. When applied to non-friction internal engine surfaces, it functions similarly to Glyptal — while offering significantly improved performance.
Key Benefits of RustSeal for Engine Internals
- Extremely strong adhesion to cast metal
- Seals porous surfaces permanently
- Resistant to engine oil, fuel, and additives
- Excellent chemical and corrosion resistance
- Creates a hard, non-porous protective barrier
Recommended Internal Engine Areas
RustSeal may be applied to non-machined internal cast surfaces such as:
- Lifter valley
- Crankcase interior
- Timing cover interior
- Oil drain-back areas
- Pushrod gallery surfaces
Surface Preparation
Proper preparation is critical for success.
- Degrease thoroughly to remove all oil residue with KBS Klean
- Rinse and dry completely
- Etch the surfaces with RustBlast
- Carefully mask machined areas and oil passages
Application Guidelines
Apply RustSeal in thin, even coats using a brush. Avoid heavy buildup or pooling. Two light coats are typically sufficient.
Complete RustSeal Application Directions: kbs-coatings.com/rustseal-directions
Allow the coating to fully cure before engine assembly. Full chemical cure typically occurs within 3–5 days depending on temperature and humidity.
Why Builders Choose RustSeal Over Traditional Glyptal
- Superior chemical resistance
- Permanent moisture-cured bonding
- Excellent oil and fuel resistance
- Long-term durability without softening
When used correctly, RustSeal provides professional-grade internal engine protection designed to last the life of the engine.
Can RustSeal be used inside an engine like Glyptal?
Yes. When applied to non-friction internal cast surfaces, RustSeal can be used similarly to Glyptal to seal porous metal, prevent corrosion, and improve internal cleanliness.
Is RustSeal resistant to engine oil?
Once fully cured, RustSeal is highly resistant to engine oil, fuel, and common additives.
Can RustSeal be applied to cylinder walls or bearings?
No. RustSeal should never be applied to cylinder walls, bearings, journals, or any machined tolerance surfaces.
How long should RustSeal cure before engine assembly?
Allow a minimum of 24 hours before handling and 3–5 days for full chemical cure prior to engine assembly.
