How to Seal a Metal Fuel Tank Inside and Out to Stop Rust and Extend Its Life
Sealing a metal fuel tank is one of the most effective ways to stop rust, prevent fuel contamination, and extend tank life—whether the tank is already rusty or brand new. This step-by-step guide shows how to seal the inside of a tank using a dedicated kit, then protect the outside with a durable rust-preventive coating. We’ll use the KBS Tank Sealer Kits plus KBS RustSeal.
Metal fuel tanks rust internally from condensation and ethanol-blended fuels, and externally from road spray, salt, dirt, and debris. Done correctly, sealing isolates metal from moisture and oxygen—the two things corrosion needs to continue.
Why fuel tanks rust from the inside
Internal corrosion is most often caused by condensation. As temperatures rise and fall, moisture accumulates inside the tank—especially when stored partially full. Ethanol-blended fuels can worsen the problem by attracting and holding moisture against metal.
- Rust flakes break loose and contaminate fuel
- Filters, carburetors, and injectors clog
- Corrosion spreads into seams and low points
- Metal thins, eventually leading to pinholes and leaks
Why seal a rusty fuel tank instead of replacing it?
Replacement isn’t always practical. Original tanks for classics can be hard to find, expensive, or poorly reproduced. If the tank is structurally sound, sealing is often the best way to restore reliability and prevent ongoing contamination.
- Encapsulates remaining corrosion
- Stops rust flakes from contaminating fuel
- Seals seams and microscopic pinholes
- Extends service life—often for decades
Why seal a new metal fuel tank?
Many builders seal new tanks proactively to prevent rust before it starts. New or reproduction tanks may have minimal internal protection and can still rust during storage or seasonal use.
- Adds corrosion protection from day one
- Improves resistance to ethanol blends
- Protects stored/seasonal vehicles
- Reduces future rust repair risk
System overview
Long-term success depends on preparation. Tank sealers fail when residue, loose rust, or smooth/unedged metal prevents adhesion. The KBS system uses a proven prep + seal process:
- KBS Klean – removes varnish, fuel residue, oil, and contaminants
- KBS RustBlast – dissolves rust and etches steel for adhesion
- Gold Standard Tank Sealer – creates a permanent fuel-resistant lining
How to seal the inside of a metal fuel tank
If a tank was previously sealed: remove the old liner first using KBS Strip, then continue with the steps below. (Follow the product directions for safe use and complete removal.)
Step 1: clean the tank with KBS Klean
Cleaning is the foundation. Any residue left behind can cause the sealer to lift or peel later. KBS Klean is a water-based degreaser designed to remove contaminants without leaving adhesion-hindering residue.
- Mix 1 part KBS Klean with 1 part hot water
- Pour into the tank and seal all openings
- Agitate and rotate the tank to reach all internal surfaces
- For heavy varnish: soak longer as needed; rotating with clean nuts/bolts or a loose chain can help dislodge debris
- Drain and rinse repeatedly with clean water
Full kit directions can be found here: tank sealer directions.
Step 2: remove rust and etch metal with KBS RustBlast
KBS RustBlast removes corrosion and etches the steel to create the ideal surface for the sealer to lock onto.
- Pour RustBlast into the tank
- Roll/tip the tank to keep all interior surfaces wet for 30–60 minutes
- Do not allow RustBlast to dry on the surface
- Drain and rinse thoroughly with water
- Dry completely using forced air (shop vac/blower/fan) and/or gentle heat
A white zinc-phosphate film may remain after drying—this is beneficial for adhesion and flash-rust prevention. Full kit directions: tank sealer directions.
Step 3: apply Gold Standard Tank Sealer
With the tank clean, etched, and totally dry, apply the sealer. This is a single thin-coat application. Take your time to fully coat the entire interior, paying extra attention to seams and low points.
- Avoid working in direct sun or near direct heat
- Mix thoroughly (stir from the bottom up)
- Pour the entire can into the tank and slowly rotate to coat all surfaces (work for up to ~30 minutes)
- Drain excess until dripping stops
- Continue rotating occasionally to minimize pooling
- Pooling or heavy buildup can cause curing/adhesion issues—keep it thin and even
Allow 96 hours for full cure before putting the tank into service. Product page: Gold Standard Tank Sealer.
Why coat the outside of a fuel tank?
Even if the inside is sealed, the outside remains exposed to moisture, road spray, and salt. Many tanks fail from the outside first. Coating the exterior helps protect seams, edges, and mounting points from corrosion.
How to coat the outside of a fuel tank with RustSeal
Step 1: clean and remove loose rust
- Mix KBS Klean with hot water (1:5)
- Scrub thoroughly, rinse, and dry completely
- Remove loose rust mechanically: wire brush, 60–80 grit sanding, or sandblasting for best results
Step 2: treat with RustBlast
- Spray RustBlast on and keep wet for 30 minutes to 2 hours, depending on severity
- Scrub intermittently with a Scotch-Brite pad
- Rinse and dry thoroughly
- A whitish zinc-phosphate residue may remain—do not remove it
Step 3: apply RustSeal
KBS RustSeal is a 1K moisture-cured urethane that forms a rock-hard yet flexible barrier. It can be applied to bare, treated, or properly prepared rusted metal surfaces.
- Methods: brush, roll, or spray equipment
- Temperature: apply between 55°F and 82°F; avoid high humidity/rain
- Mix thoroughly: stir from the bottom up
- Apply at least three thin coats (thin coats cure harder/stronger than thick coats)
- Recoat: once dry to the touch (2–6 hours), apply additional coats within 8 hours
- Cure: handle after 1 day; full cure in 7 days before service
Full directions: rustseal directions.
Patching the outside of the tank (if necessary)
For exterior repairs before coating, pinholes/weld seams can be reinforced with KBS BackBone Reinforcing Mesh. For holes larger than pinholes, use NuMetal Epoxy Putty. Perform repairs before applying RustSeal.
Detailed kit directions: tank sealer directions.
Benefits of sealing and coating a fuel tank inside and out
- Stops rust inside the fuel tank
- Prevents fuel contamination
- Protects against exterior corrosion
- Extends tank service life (often by decades)
- Usually costs far less than replacement
Frequently asked questions
Is sealing a fuel tank permanent?
When properly prepared and cured, tank sealers can last for decades without peeling or failure.
Can you seal a rusty fuel tank?
Yes—as long as the tank is structurally sound and the preparation steps are done correctly.
Should you coat the outside of a fuel tank?
Yes. Exterior corrosion is one of the most common causes of fuel tank failure, especially in wet or salty climates.
Final thoughts
Sealing a metal fuel tank the right way—and protecting it both inside and out—is one of the smartest steps you can take in a restoration or long-term maintenance plan. Don’t rush prep. Preparation determines adhesion, durability, and long-term success.
