How to Paint a Motorcycle Engine So It Doesn't Peel, Flake, or Burn Off
If you want a finish that won't peel, flake, or burn off, painting a motorcycle engine comes down to proper prep, the right coating, and applying it correctly. Most failures happen due to surface contamination, poor adhesion, or using the wrong paint. This guide walks you through how to clean, prep, and coat your engine for a durable, long-lasting finish.
Why Motorcycle Engine Paint Fails
Motorcycle engine paint often fails due to contaminants, poor surface preparation, incorrect coating selection, or applying paint too thickly.
  • Contaminants hinder paint adhesion. Dirt, oil, grease, fuel, silicone, oxidation, cleaner residue and other contaminants left on engine surfaces prevent proper paint adhesion, causing peeling, fisheyes, or failure.
  • Painting over corrosion. Loose, untreated rust and corrosion don't provide a stable surface for the coating, causing it to lift, bubble and peel.
  • Using paint not rated for engine temperatures. Applying paint and coatings not designed for high temperatures can cause them to crack, peel, discolor and burn off.
  • Thick coats trapping solvents. Paint applied too thickly can skin over, trapping solvents and preventing proper off-gassing, which leads to improper curing.
The KBS Motor Coater Kit Facilitates Proper Prep and Application
The DIY-friendly Motor Coater Kit has everything needed for a long-lasting paint job, including preparation products and high-temperature engine enamel.
How Hot Does a Motorcycle Engine Get?
Use of high-temperature coatings is critical when you paint a motorcycle engine. Consider typical temperature ranges:
  • Engine block — 150–250°F
  • Cylinder head — 300–450°F
  • Near exhaust ports, temperatures can spike to 500°F+
Why Do Standard Engine Paints Fail?
Standard motorcycle engine paint fails because heat breaks down their binders, causing softening and loss of adhesion. Oxidation leads to discoloration, and repeated heat cycles cause cracking, flaking, and eventual peeling of the coating.
Best Paint for Motorcycle Engines
Use a high-temperature engine enamel rated for at least 500°F. Standard paints will fail under heat, causing peeling, discoloration, and loss of adhesion.
Motor Coater Engine Enamel resists temperatures to 500°F and produces a finish that won't blister, flake, crack, or peel.
The Most Important Step: Proper Engine Preparation
Thorough preparation makes the difference between a paint job that lasts and one that quickly fails.
Cleaning and Degreasing (Why Most Paint Jobs Fail)
Oil seepage, road grime, baked-on residue and other contaminants prevent paint from adhering properly, causing lifting and peeling. Included in the kit is KBS Klean, a powerful degreaser and cleaner that removes contaminants without leaving adhesion-hindering residue.
Removing Rust and Corrosion
Loose, untreated rust and corrosion create an unstable surface that prevents proper adhesion, causing the coating to lift, bubble, and peel while oxidation continues to progress.
Rust and corrosion can be removed using mechanical methods such as wire wheeling, sanding, or sandblasting, through chemical treatment, or by a combination of both.
KBS RustBlast is included in the Motor Coater Kit for chemical treatment. KBS RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. Applied to bare metal or light corrosion, it neutralizes oxidation and leaves a micro-etched profile that promotes strong coating adhesion.
Why Prep Determines Adhesion
It's important to take time and follow proper procedure to thoroughly prepare metal before applying motorcycle engine paint. Paint sticks to clean, profiled surfaces — not metal alone.
Can You Paint a Motorcycle Engine Without Removing It?
It's possible to paint a motorcycle engine that's still mounted on the motorcycle, but it depends on:
  • Access to the surfaces to be prepared and coated.
  • Ability to properly mask areas that aren't to be painted.
  • Application method (spraying or brushing).
Pros of Painting in Place
  • Less labor.
  • No teardown required.
Challenges
  • Tight areas.
  • Overspray risks.
  • Coverage limitations.
Why Brushing Works Well With the Engine in Place
  • Control in tight areas.
  • Self-leveling coatings eliminate brush marks.
Motor Coater works great for brushing as it yields a self-leveling, professional-looking finish. The engine enamel is available in over 40 deep, rich pigmented colors for excellent coverage.
Step-by-Step: How to Paint a Motorcycle Engine the Right Way
Carefully follow these steps for a durable and long-lasting finish.
Step 1 – Remove Rust and Paint
Remove all loose flaking rust with a wire brush and/or wire wheel. Alternately this can be done with 320-grit sandpaper or by sandblasting. Also remove existing paint with a chemical stripper such as KBS Strip or by sandblasting.
If unable to remove any or all paint from metal surfaces, lightly scuff with 400-grit sandpaper. Any remaining paint must be firmly adhered.
Step 2 – Clean and Degrease
Remove all surface contamination with KBS Klean.
  • Mix KBS Klean with warm water.
  • Dilution rates will vary according to the type and degree of contaminants as well as whether the metal is ferrous or non-ferrous.
  • Scrub with a sponge or bristle brush.
  • Rinse and dry thoroughly.
Full instructions for KBS Klean, including recommended dilution rates, can be found on the KBS Klean directions page.
Step 3 – Prep the Surface
Apply KBS RustBlast to dissolve remaining rust and etch the surface for adhesion of Motor Coater.
  • Spray it on and keep wet for 30 minutes to 2 hours, depending on rust or corrosion severity.
  • Scrub intermittently with a Scotch-Brite pad.
  • A whitish zinc-phosphate residue will remain — this is beneficial and prevents flash rust. Do not remove it.
Note: when using KBS RustBlast it's not necessary to remove every trace of rust before applying Motor Coater.
Full instructions for KBS RustBlast can be found on the KBS RustBlast directions page.
Step 4 – Mask Off Components
Mask off intake openings, exhaust ports, throttle bodies, wiring, sensors, spark plug holes, fuel lines, hoses, belts, and sealing surfaces. Protect bearings, seals, and electrical components.
Step 5 – Apply Coating
Apply Motor Coater by brushing or spraying.
  • Optimal temperature: Apply between 55–82°F, avoiding rain or high humidity.
  • Mix thoroughly: Stir from the bottom of the can to the top before use.
  • Thinning/Reducing: When spraying, thinning is generally not required, but if needed, 5–10% is normally adequate. Thin with KBS #1 Thinner or xylene only.
  • Application: In most cases, a single full coat of Motor Coater will cover completely with full color depth. Do not apply paint too thick.
Step 6 – Apply Additional Coats Properly
If desired, a second coat may be applied within 30 minutes or after 7 days.
Step 7 – Cure Time
Average cure times are 2–4 hours; however, depending on humidity and temperature levels, dry times may vary.
Full instructions for Motor Coater can be found on the Motor Coater directions page.
Common Mistakes That Cause Engine Paint to Fail
  • Painting over oil, grease, and other contaminants.
  • Skipping proper cleaning and surface prep.
  • Applying coating too thick, trapping solvents.
  • Using the wrong coating.
  • Not allowing proper dry and cure time.
Final Thoughts: How to Paint a Motorcycle Engine for a Long-Lasting Finish
For a motorcycle engine paint job that lasts, success comes down to thorough cleaning, proper surface prep, and using a high-temperature engine enamel applied in thin, even coats. By following the correct steps and using KBS Klean, KBS RustBlast, and Motor Coater, you'll prevent peeling, flaking, and burn-off while achieving a durable, professional-quality finish.
Shop the Products Used in This Guide
KBS Klean  KBS RustBlast  Motor Coater Kit
