Impressed with KBS Products On My 72" Mower Deck
In these times of social distancing and stay at home orders, may of us are looking at projects around the house that may be long overdue. Many of our customers have turned to our paint products for restoring their equipment that may be rusty now or may rust down the road if not coated with a rust preventative coating.
Matthew P tells us: "I just wanted to say how impressed I've been with KBS products. I recently purchased a 72" finish mower that was mechanically sound but had lots of surface rust. I started with the underside of the deck and used the Frame Coater Kit with fantastic results. For the top of the deck I used the Klean/Blast/Seal process, then KBS Top Coater and then DiamondFinish Clear. I couldn't be happier with the results and I fully expect this thing to outlast me. Also worth mentioning is that KBS customer service is first-rate. They guided me on what products to use and delivery was super fast. Looking forward to more projects!”.
The KBS Products that he used are ideal for restoring a mower deck. The KBS Klean and RustBlast will prep the steel surface so that the rust is removed and the surface is etched leaving an anchor pattern on the surface of the metal that is ideal for paint adhesion. RustSeal prevents rust and is extremely durable which is a necessity for a mower deck on both the topside and the underneath.
The KBS Top Coater is a high solids UV stable coating that covers extremely well and leaves a beautiful finish that is very visible and also extremely durable. DiamondFinish Clear is a water clear coating that adds gloss and provides additional protecion and durability. Using the combination of all of those products left him with not only a beautiful finish but a finish that will be very easy to wash and clean after each use. The investment in a high quality coatings system will protect his equipment investment for years to come.
