“1976 Honda trail 70 I restored using all KBS products. KBS Strip, RustBlast, RustSeal Black and Crazy Plum MAXX paint and DiamondFinish Clear... All products worked just like they said they would. MAXX and Clear sprayed perfect with high gloss and no runs ... As a matter of fact I couldn't make it run! All dried super hard! Then used KBS UnderCoat inside frame. On motor cases I used the silver Motor Coater and topped Motor Coater with the DiamondFinish Clear. I tell all my friends about how good KBS Products are!” -Robert T.
KBS Strip is a powerful aircraft strength paint remover that sprays as a semi gel coat for fast and easy coverage when stripping motorcycle parts. KBS Strip produces an even, unbroken film which seals and allows deep penetration through multiple layers of paint. KBS Strip will cling to vertical surfaces with minimal run or sag and offers low-odor technology. KBS Strip is the next generation of Paint Strippers containing no harmful Methylene Chloride.
KBS MAXX is a superior performance, two-component (2K), low VOC, low HAPs, permanently UV stable polyurethane topcoat that can be applied by brush, roller or sprayer making it ideal for motorcycle restorations. KBS MAXX is specifically designed for the indoor and outdoor applications including automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
Motor Coater is easy to apply, offers superb coverage and yields a self-leveling professional looking finish brushed or sprayed. These engine enamels provide deep, rich pigmented colors for excellent coverage on motorcycle engines.
DiamondFinish Clear is a crazy tough Clear Coat ideal for motorcycles that can be applied Direct To Metal or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling making it ideal for motorcycle restoration.
