Dock environments are harsh—constantly exposed to water, humidity, sunlight, and wind-driven spray. Metal dock decking and metal components such as hardware, brackets, railings, and fasteners are in continual contact with moisture, oxygen, and often salt, all of which promote rust and corrosion. If left unaddressed, these elements can weaken over time and fail suddenly, leading to loose boards, unstable railings, or even structural collapse.
Beyond the safety hazards, corrosion also diminishes the dock’s appearance and longevity. With consistent inspection and proper maintenance, rust and corrosion can be managed—but neglect dramatically increases the risk of costly and dangerous failures.
In this article, we’ll show the steps to effectively stop and prevent rust and corrosion on steel and aluminum docks and hardware using KBS Klean, RustBlast, RustSeal, and KBS MAXX.
What Causes Rust on Metal Dock Components?
Rust and corrosion is the natural result of metal oxidation. When steel or iron is exposed to moisture and oxygen, it begins to form iron oxide — commonly known as rust. When aluminum is exposed to these elements corrosion can form. In dock environments, this process accelerates due to constant exposure to water and humidity. Even “corrosion-resistant” metals like aluminum and galvanized steel can degrade when their protective coatings are compromise.
Saltwater environments intensify the process. Salt acts as an electrolyte, speeding up rust and corrosion by allowing electrical current to pass more easily between dissimilar metals. This leads to galvanic corrosion, which occurs when two different metals (such as aluminum railings and stainless-steel fasteners) make contact in a wet environment.
How Can Rust and Corrosion Be Permanently Stopped on Docks?
Rust and corrosion can be permanently stopped and prevented by applying RustSeal, a tough 1K moisture-cured urethane rust and corrosion preventive coating that provides a permanent barrier to seal metal away from moisture, oxygen, and corrosives like salt. RustSeal dries to a rock-hard yet flexible finish. It doesn’t chip or peel, and it can be applied directly to rusted and corroded metal, treated metal, or bare metal surfaces.
Do Aluminum and Galvanized Dock Railings Still Need Rust Protection?
While aluminum and galvanized docks, railings, and components generally require less maintenance than steel when their finishes remain intact, they’re not immune to corrosion. In wet environments—and especially in saltwater conditions—aluminum and galvanized steel can still deteriorate where protective coatings are damaged. Therefore, it’s just as important to coat these metals with RustSeal as it is to coat exposed steel.
Why Is Coating Dissimilar Metals Important on Docks?
One often-overlooked aspect of dock maintenance is galvanic corrosion. When two dissimilar metals—like aluminum railings and stainless-steel bolts—contact each other in the presence of water, one metal becomes the sacrificial anode and corrodes faster. Coating both metals with RustSeal creates an insulating barrier that prevents this electrochemical reaction entirely.
What’s the Correct Process for Preparing Metal Before Coating?
Step 1: Remove Loose Rust, Corrosion, and Paint
Start by removing loose rust and paint to create a stable foundation for coating.
  • Use a wire brush, 320-grit sandpaper, or sandblasting.
  • Sandblasting offers the most thorough surface preparation. When sandblasting, RustBlast is not needed—RustSeal can be applied directly to newly sandblasted metal that has been handled only with gloved hands. Simply blow off loose dust and go straight to applying RustSeal.
  • Lightly scuff any well-adhered original paint with 320-grit sandpaper before proceeding.
Removing unstable material ensures that RustSeal bonds directly to solid, corrosion-free surfaces. RustSeal can still be applied over light surface rust once it has been treated with RustBlast, so sanding to bare metal isn’t required.
How Do You Clean Dock Railings and Hardware Before Coating?
Step 2: Clean the Surface with KBS Klean
Thorough cleaning is essential for rust prevention and strong coating adhesion. KBS Klean is a powerful water-based cleaner and degreaser that removes contaminants without leaving residue.
Directions:
  • Mix KBS Klean with hot water.
    • For steel: Mix between 1:1 to 1:10 depending on soil level.
    • For aluminum and non-ferrous metals: Mix no less than 1:25.
  • Scrub with a sponge or bristle brush.
  • Rinse and dry thoroughly.
Clean surfaces allow the coating to bond properly, ensuring long-term protection for dock hardware and metal components. Full directions: KBS Klean Directions.
How Do You Neutralize Rust and Etch Metal for Coating?
Step 3: Neutralize Rust and Corrosion with RustBlast
RustBlast is applied to bare metal or areas with light rust or corrosion to neutralize existing oxidation and create an ideal surface profile for RustSeal adhesion.
Directions:
  • Spray on and keep wet for 30 minutes to 2 hours, depending on rust or corrosion severity.
  • Scrub intermittently with a Scotch-Brite pad.
  • A whitish zinc-phosphate residue will remain—this is beneficial and prevents flash rust. Do not remove it.
  • RustBlast not only stops active rust and corrosion but also leaves a micro-etched surface profile that promotes superior adhesion for RustSeal. Full directions: RustBlast Directions.
How Do You Apply RustSeal for Long-Term Protection?
RustSeal acts as both an oxidation barrier and a foundation for additional coatings or finishes.
Application Guidelines:
  • Methods: Brush, roll, or spray. Brushing works best for small dock hardware; spraying offers the smoothest finish for large dock railings or sections.
  • Temperature: Apply between 55°F and 82°F. Avoid high humidity or rainy conditions.
  • Mix thoroughly: Stir from the bottom of the can upward before use.
  • Coat thickness: Apply at least three thin, even coats with overlapping strokes. Thin coats cure harder and stronger than thick ones.
  • Recoat time: Once the previous coat is dry to the touch (2–6 hours), apply additional coats within 8 hours.
  • Cure time: Handle after one day; full cure in seven days.
When applied correctly, RustSeal creates a tough, flexible barrier that permanently seals out moisture, oxygen, and salt—eliminating future rust and corrosion on metal dock components. Full instructions: RustSeal Directions
Why Should RustSeal Be Top Coated for UV Protection?
RustSeal provides unmatched corrosion protection but isn’t designed for direct UV exposure. Over time, sunlight can slightly alter its sheen or color, though its rust-preventive properties remain unaffected. For a UV-stable finish, apply a top coat such as KBS MAXX.
What Makes KBS MAXX Ideal for Dock Applications?
KBS MAXX is a 2K moisture-cured polyurethane coating that provides:
  • Outstanding gloss and color retention.
  • Exceptional impact and abrasion resistance.
  • Fast-drying characteristics.
  • Superior UV stability.
Available in a variety of colors, KBS MAXX delivers the protection and appearance needed for long-lasting rust-proof dock railings and other exposed structures. It can be applied by brush, roller, or spray and forms a rock-hard finish ideal for marine and waterfront environments.
How Should RustSeal Be Prepared Before Applying MAXX?
To ensure strong adhesion between RustSeal and KBS MAXX, surface preparation is key.
Options for preparing RustSeal before top coating:
  1. Apply KBS MAXX once RustSeal’s second or final coat is dry-to-the-touch and no longer leaves a fingerprint (usually 3–6 hours).
  2. After full curing (24 hours), scuff with 320-grit sandpaper, then apply KBS MAXX.
  3. Alternatively, after curing, lightly dust with KBS Fusion SEP - Self-Etching Primer, allow 30 minutes to dry, then apply KBS MAXX.
This process ensures the marine dock railing rust-resistant coating adheres strongly and delivers long-term UV protection.
How Do You Mix KBS MAXX Properly?
Proper mixing ensures chemical balance and optimal curing.
Mixing Instructions:
  • Apply between 50–82°F in moderate humidity. Avoid extreme heat, cold, or wet conditions.
  • Begin by thoroughly mixing KBS MAXX Base using a mechanical mixer (e.g., KBS Hurricane Paint Mixer).
  • Once fully mixed, measure 3 parts KBS MAXX Base and 1 part KBS MAXX Activator into a clean container.
  • Mix thoroughly until the consistency is uniform.
This 3:1 ratio activates the curing process, producing a coating that resists UV damage and mechanical wear—ideal for dock rust and corrosion prevention.
How Do You Apply KBS MAXX Over RustSeal?
Application Tips:
  • Apply a minimum of three thin, even coats.
  • Multiple thin coats provide better adhesion and durability than a few thick ones.
  • Avoid puddling and pooling.
  • When brushing or rolling, apply and move on immediately rather than overbrushing.
  • For the best results, maintain consistent environmental conditions throughout the application.
What Are the Recommended Application Methods?
When Brushing:
  • KBS MAXX Base and Activator are pre-thinned for brushing, rolling, or spraying.
  • Additional thinning (up to 10%) may be done using KBS #1 Thinner or Xylene.
When Rolling:
  • Use a high-density foam roller to achieve a smooth, even finish.
When Spraying:
  • Always wear an air-supplied respirator or NIOSH/MSHA-approved organic vapor respirator.
  • For spray applications, thin by 10–15%, or up to 30% if needed, with KBS #1 Thinner or Xylene only.
How Long Does KBS MAXX Take to Dry and Cure?
Curing depends on temperature, humidity, and film thickness. Ideal conditions are 77°F and 70% relative humidity.
Typical cure times:
  • Dry to the touch: ~30 minutes.
  • Fully dry: 1–2 hours.
  • Hard cure: 3–4 hours.
  • Full cure: 7 days.
Keep in mind KBS MAXX is moisture-cured, it cures faster in humid environments.
Detailed directions: KBS MAXX Directions.
What Are the Long-Term Benefits of Using KBS Coatings on Docks?
Applying KBS Klean, RustBlast, RustSeal and KBS MAXX provides multiple layers of protection that address every stage of the corrosion process:
  • Surface cleaning eliminates contaminants that interfere with coating adhesion.
  • Rust and corrosion neutralization stops existing oxidation and prepares the surface for coating.
  • Sealing with RustSeal locks out oxygen, moisture, and salt.
  • Top coating with KBS MAXX ensures UV stability and an attractive finish that resists chipping, fading, and cracking.
This multi-step approach not only eliminates existing rust and corrosion but also prevents new oxidation from forming — extending the life of your dock, railings, and hardware for years.
Conclusion: What’s the Best Way to Protect Metal Dock Railings from Rust?
Preventing rust on docks requires more than quick touch-ups — it demands a comprehensive, science-based process. Using the KBS Coatings system—KBS Klean, RustBlast, RustSeal, and KBS MAXX—provides a professional-grade, permanent solution for rust repair on dock rail hardware and all exposed metal dock components.
By cleaning, neutralizing, sealing, and protecting with the right products, you can achieve long-lasting protection and a professional finish. Whether you’re working with aluminum or steel structures, this proven system delivers the best rust and corrosion protection in marine and freshwater environments alike.
By thoroughly cleaning, neutralizing, sealing, and protecting with the proper products, you can ensure long-term corrosion resistance and a durable, professional finish. Whether your dock and components are constructed from steel or aluminum, this proven system provides unmatched rust and corrosion protection in both marine and freshwater environments.
With the right coatings, regular inspections, and a commitment to preventive maintenance, your dock will not only look great but remain safe, stable, and corrosion-free for decades to come.
