How to Repair and Stop Rust in a Car Floor Pan (Daily Drivers & Classic Cars)
If you’ve found rust in your floor pan, you’re at a decision point: ignore it and let it spread, or fix it correctly to permanently protect your vehicle's value.
This guide explains the professional way to fix rust in a car floor pan. You’ll learn how to evaluate damage, decide if welding is necessary, and properly clean, treat, and coat metal using the complete KBS system: KBS Klean, KBS RustBlast, and KBS RustSeal.
Identifying Your Floor Pan Rust
Before choosing a repair method, identify which level of corrosion you are facing:
1. Surface Rust
- Light orange or brown discoloration
- No soft spots or holes; metal remains solid
2. Scaling Rust
- Flaking metal and deep pitting
- Visible corrosion layers, but structural integrity remains
3. Structural Rot
- Soft spots, holes, or cracking metal
- Requires metal patches or KBS BackBone Mesh reinforcement.
Do You Need to Weld the Floor Pan?
If you have holes, the repair method depends on size and location:
- Pinholes to 1/2": Use NuMetal Epoxy Putty.
- 1/2" to 3": Use a combination of KBS BackBone Mesh and epoxy putty.
- 3"+ or Structural Areas: (Seat mounts, supports) Welded metal patches are strongly recommended.
The Best Way to Fix Rust: Step-by-Step
Step 1: Clean and Degrease with KBS Klean
Adhesion failures are usually caused by invisible residues like old adhesives or road salt. Mix KBS Klean with warm water (1:5 ratio), scrub thoroughly, rinse, and let dry.
Step 2: Remove Loose Rust and Scale
Use a wire wheel, 60-80 grit sandpaper, or sandblasting to remove flaking material. You don't need to grind to bare silver; you just need to reach solid metal.
Step 3: Treat and Etch with RustBlast
This step neutralizes remaining rust and etches the surface for a permanent bond. Spray RustBlast, keep it wet for 30 minutes, then rinse and dry completely.
Step 4: Seal with RustSeal
Apply at least three thin, even coats of KBS RustSeal. This moisture-cured urethane creates a rock-hard barrier that blocks moisture and salt permanently.
Common Mistakes to Avoid
- Painting over loose rust: If the rust flakes off later, the paint goes with it.
- Skipping the Etch: Without RustBlast, the coating cannot "bite" into the metal.
- Ignoring the Moisture Source: Always check for leaking windshield seals or heater cores before re-carpeting.
Ready to fix it once and fix it right?
Shop the Complete Trunk & Floorpan Repair Kit Here.
Ready to Start Your Restoration?
For a deep dive into every detail, including drying times, mixing ratios, and advanced application tips, check out our full technical guide.
VIEW COMPLETE APPLICATION DIRECTIONSFIND
