How To Attach The Cavity Wand to KBS Cavity Coater Aerosol
In this video, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can.
The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and also applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F.
Cavity Coater Aerosol is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. Cavity Coater Aerosol provides a self-healing film which provides insane rust protection on hard to reach areas.
