A Proper Body Repair Method That Keeps Rust from Coming Back
When performing auto body repairs, it can be difficult to completely neutralize existing rust. Even small traces can continue to grow beneath new coatings and fillers, leading to rust reappearing later. Likewise, if metal remains exposed to moisture or oxygen after the repair, rust can begin to form—often where you least expect it, such as behind panels, under seams, or beneath filler.
The good news is that with the proper rust prevention process, future corrosion can be stopped before it starts. This article shows a proven rustproofing auto body repair method that ensures long-term durability. By thoroughly preparing metal and sealing repairs you can confidently complete collision repairs that aren’t prone to rust.
Why Does Rust Return After Auto Body Repair?
Rust often returns because the original corrosion was never fully neutralized, or because oxygen and moisture still have a path to reach the metal. Even the smallest gap in primer, filler, or paint can allow rust to re-form beneath the surface. Another common cause is improper cleaning or incomplete priming of bare metal after grinding or welding.
The key to rust prevention after body repair is to completely isolate the metal from air and moisture. To achieve this, RustSeal provides an extremely durable and impervious rust preventive coating that permanently locks out air and moisture.
What Makes RustSeal Ideal for Preventing Rust After Collision Repair?
RustSeal is a rust preventive coating for body repairs that delivers a permanent barrier between metal and the environment. It’s a 1K moisture-cured urethane formula that dries to a rock-hard yet flexible finish. RustSeal doesn’t chip or peel, and it can be applied directly to rusted, treated, or bare metal surfaces.
RustSeal can serve as the foundation for all layers that follow—primers, fillers, putties, and paints—ensuring that rust cannot form underneath them. It can also be applied over fillers and putties which have been previously applied directly to the metal. However, it is highly important to ensure no moisture is trapped within those repairs before coating, as trapped moisture can create rust.
RustSeal can be applied by brush, roller, or spray, providing quality results whether used professionally or at home. Once cured, it forms a seamless, impermeable coating that resists water, salt, chemicals, and impact.
By using RustSeal as a base coat, you ensure your repair is completely sealed against oxygen and moisture, keeping rust from forming.
How to Prepare Metal for RustSeal: Cleaning and Surface Conditioning
Proper surface preparation is critical for RustSeal to bond effectively, prevent future rust, and create a solid foundation for paints, fillers, and putties. The metal must be free of debris, contaminants, and rust that can hinder adhesion. The metal also needs to be micro-etched to create an ideal surface profile for RustSeal to bond securely, and any remaining light surface rust must be fully neutralized. For this, KBS Coatings offers KBS Klean for cleaning, and RustBlast to treat the metal.
Keep in mind, if patch panels or new body panels are being welded in, both the existing panel and replacement panel should be cleaned and treated with KBS Klean and KBS Klean before welding.
Step 1: Remove Loose Rust and Paint
  • Use a wire brush, 320-grit sandpaper, or sandblasting.
  • Note: Sandblasting offers the fastest and most thorough way to completely remove rust. When sandblasting, KBS Klean isn’t needed; RustSeal can be directly applied to newly sandblasted metal surfaces that have been handled with gloved hands. No preparation other than blowing off loose dust is required. Proceed to the “Step 4: Apply RustSeal” section after sandblasting.
  • Lightly scuff any well-adhered original paint with 320-grit sandpaper before proceeding.
Removing loose rust and paint ensures that RustSeal bonds directly to solid, stable material. Keep in mind that RustSeal can be applied over light surface rust once it has been treated with RustBlast, so complete sanding down to bare metal isn’t necessary.
Step 2: Clean the Surface with KBS Klean
Thoroughly wash the surface using KBS Klean , a powerful degreaser and cleaner. This removes dirt, grease, and grime, without leaving adhesion-hindering residue, ensuring that the surface is ready for KBS Klean. Clean surfaces allow KBS products to work most effectively.
  • Mix KBS Klean with warm water and scrub with a sponge or bristle brush.
  • Rinse and dry thoroughly.
  • Full instructions: https://www.kbs-coatings.com/kbs-klean-directions
KBS Klean is a water-based cleaner that’s safe for all automotive metals and won’t leave a film behind. Thorough cleaning is a crucial step when rustproofing auto body repairs.
Step 3: Neutralize Rust with RustBlast
For bare metal and areas with existing rust, RustBlast is applied. RustBlast penetrates, dissolves, and neutralizes rust to stop its progression and etches the metal for best adhesion of RustSeal.
  • Spray on and keep wet for 30 minutes–2 hours depending on the amount of rust.
  • Scrub intermittently with a Scotch-Brite pad.
  • A whitish zinc-phosphate residue will remain; this prevents flash rust. Do not remove.
  • Full instructions: https://www.kbs-coatings.com/rustblast-directions
RustBlast is one of the most important steps in priming bare metal after repair because it readies the surface for permanent sealing.
Apply RustSeal for Long-Term Protection
RustSeal not only serves as the rust-preventive foundation for primers, fillers, and putties—it can also be applied over previously repaired areas where filler has been used. However, it’s critical that no moisture is trapped beneath these materials before applying RustSeal, as that can lead to rust formation under the coating.
  • Choose your application method: Brushing, rolling, or spraying; brushing is generally best for small repairs, while spray equipment provides the smoothest finish for larger areas.
  • Optimal temperature: Apply between 55–82°F, avoiding rain or high humidity.
  • Mix thoroughly: Stir from the bottom of the can to the top before use.
  • Thinning/Reducing: When spraying, thinning is generally not required, but if needed, 5–10% is normally adequate.
  • Apply in thin overlapping coats: At least three thin, even coats; multiple thin coats are better than a few thick ones.
  • Re-coating: Once the previous coat is dry to the touch (2–6 hours), apply additional coats within 8 hours.
  • Coating over rust: RustSeal can be applied over treated light surface rust if desired.
  • Cure time: The area can be handled after 1 day, and full cure takes place in 7 days.
  • Full instructions: https://www.kbs-coatings.com/rustseal-directions
If patch panels or new body panels are welded into place after using KBS Klean and RustBlast, use KBS Klean and RustBlast at the repair site before the application of RustSeal. It is very important to thoroughly coat the repair on both the front and backside to completely seal the metal.
Apply a Top Coat for UV Stability
Top coating RustSeal is recommended since it isn’t intended as a final finish for surfaces exposed to direct sunlight. UV light may alter its color or sheen. Its rust protection remains fully effective. To protect against unwanted cosmetic changes, RustSeal can be top coated with any opaque paint system.
How to Prepare RustSeal for Top Coating
  1. Apply a top coat once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3–6 hours).
  2. Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff with 320-grit sandpaper, then apply a top coat.
  3. Let the RustSeal fully cure (at least 24 hours), dust with KBS Fusion SEP - Self-Etching Primer, let that cure for 30 minutes, then apply a top coat.
Applying Body Filler or Putty Over RustSeal
RustSeal provides a rock-solid foundation for fillers and putties. Applying these materials directly to properly cured RustSeal ensures the underlying metal stays rust-free indefinitely.
Before applying fillers or putties, first prep and coat the area with RustSeal as previously described and allow it to cure for 24 hours. Then prepare RustSeal to promote adhesion between it and the body filler or putty. This can be done in one of two ways:
Scuffing Method
  • Scuff the RustSeal with 320-grit sandpaper to provide grip for the body filler.
Self-Etching Primer Method
This process ensures the filler bonds mechanically and chemically, while RustSeal keeps oxygen and moisture completely sealed out—crucial for sealing body filler to prevent rust.
Protect Hidden Areas with Cavity Coater
Not all areas can be easily reached with a brush or spray gun. To ensure complete coverage and protection in seams, welds, and hidden cavities, KBS Cavity Coater provides internal corrosion protection where RustSeal cannot reach.
After RustSeal, fillers and putties have been applied, Cavity Coater Aerosol can be used to protect against rust in hard-to-reach areas where RustSeal cannot be applied. Cavity Coater Aerosol is a cavity wax and corrosion-inhibiting coating that can be applied with the Reusable Cavity Wand which features a 48” hose with a 360° spray tip for complete coverage.
Apply Cavity Coater
  • Minimal surface preparation required; remove loose scaly rust and clean with KBS Klean where possible. Surface must be dry.
  • Optimal temperature: 70–80°F.
  • Shake extremely well before use and occasionally during application.
  • Hold can 8–12 inches from surface.
  • Apply a thin, even coat (1 mil thickness). Cover completely but do not over-saturate.
  • Wait 10 minutes for coating to wick into seams and weld joints.
  • Remove excess with a clean rag dampened with mineral spirits.
  • For enclosed cavities, attach Reusable Cavity Wand to aerosol, insert, and withdraw at 1 foot per second; repeat for full coverage.
  • Full instructions: https://www.kbs-coatings.com/cavity-coater-directions
Using Cavity Coater provides long-term corrosion protection for inner panels, rocker panels, frame rails, and seams.
Final Thoughts: How to Ensure Rust Never Comes Back After Body Work
Thorough rust prevention after body repair achieved by cleaning, etching, sealing, and rustproofing each surface ensures your repairs last for years. The KBS Coatings system—KBS Klean, RustBlast, RustSeal, and Cavity Coater—works as a complete rust prevention strategy that professional body shops and DIY restorers can trust.
By implementing this method, you achieve:
  • Complete rustproofing auto body repairs from the inside out.
  • Maximum adhesion of primers, paints, and fillers to sealed metal.
  • Permanently keeping out moisture and oxygen—the two main causes of rust.
  • Long-term resistance to chipping, cracking, and corrosion.
For anyone serious about preventing rust after collision repair, the process outlined here represents the gold standard. Whether restoring a classic car, replacing panels after a crash, or repairing daily driver rust damage, sealing every surface properly is what keeps rust from coming back.
