The Fuel Tank Sealer Kit is all-inclusive containing everything you need to prep and seal a tank up to 25 gallons.
Tank Sealer is a superior, single-component, ready-to-use fuel tank sealer.
Gold Standard Tank Sealer is specifically formulated to stop rust and corrosion by forming a tough, fuel impervious coating while simultaneously sealing small pinholes and weld seams.
This all-inclusive kit contains KBS Klean (a water-based, heavy-duty, cleaner/degreaser) and RustBlast (a powerful rust remover/metal etch) to obtain a permanently sealed, rust-free fuel tank. These KBS prep products are formulated to promote adhesion of the Tank Sealer by leaving an ideal anchor pattern and a zinc phosphate film.
Working on a Tank with a Previous Liner?Grab KBS Strip to get the previous liner out first..
✓Steel Tanks ✓Aluminum Tanks ✓Fiberglass Tanks ✓Diesel Tanks✓Oil Tanks ✓Utility Tanks ✓Non-Potable Water Tanks ✓Air Compressor Tanks
👉 Patience When Using Tank Sealer
👉 KBS Fuel Tank Sealer System Removes Rust and Restores the Inside of Your Tank to Like New
👉 Simple Steps to Seal a Gas Tank with The KBS Coatings Tank Sealer System
Simple Steps to Seal a Gas Tank with The KBS Coatings Tank Sealer System.
Learn how to seal up a Motorcycle Gas Tank with the KBS Cycle Tank Sealer Kit which gives you everything you need to seal a tank of up to 5 gallons.
Covers cleaning the tank with KBS Klean and etching the tank with RustBlast.
4.8
The Cycle Tank Sealer Kit is a complete kit designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, utility tanks, or other small tanks up to 5 gallons. Detailed instructions are included to give you professional results.
The Large Cycle Tank Sealer Kit is designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included to give you professional, long-lasting results.
NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay no complicated weighing or measuring required. Select BLACK, TAN, WHITE or GREY.
