BlackTop is a permanent, moisture-cured, 1K, single stage, UV stable coating used for bare, painted, or primered surfaces and surfaces previously coated with RustSeal.
BlackTop adheres and bonds to bare metal surfaces - both ferrous and non-ferrous metal surfaces.
BlackTop is an incredible exterior grade rust preventative coating offering protection from the elements.
BlackTop is a long-lasting protective coating which withstands dulling and fading caused by prolonged sunlight exposure.
BlackTop may be used alone as an effective rust preventative coating and can offer the ultimate rust protection when used in combination with RustSeal.
For the best and longest-lasting rust and ultraviolet protection, first apply RustSeal to permanently seal the surface and then topcoat with BlackTop for an incredibly tough and professional looking finish.
BlackTop is available in Gloss Black, OEM Satin Black, and Flat Black.
BlackTop dries to a rock hard, yet flexible coating that can be readily applied to chassis, coil springs, and light weight panels.
BlackTop offers high heat resistance (300-500F) and can be applied to almost all automotive applications except exhaust systems.
BlackTop is available in a convenient Aerosol Spray Can! Aerosol version features a professional grade acrylic lacquer resin system for superior adhesion, color retention, and durability.
Satisfaction guaranteed!
Click HERE to Get Answers To Your Questions
