1. Home
  2. All Products
  3. Clear Coats
  4. DiamondFinish Clear - Direct To Metal or Other Coatings - 1K Water Clear Coating
213 Reviews +Write a Review
4oz: $19.95  |  Pint: $38.95  |  Quart: $56.95
Gallon: 193.95  |  5 Gal Pail: $789.95
Choose Options and Quantity
Part #: 8
Price Each: $0.00
KBS Paint Saver is a proven paint preserver that allows user-friendly long term storing of leftover paints in the original can. KBS Paint Saver keeps paints, coatings, and clear coats from skinning over in the can saving you money by allowing you to use the entire can of paint. KBS Paint Saver is environmentally safe, allows for storage of paints in their original cans, and is very easy to use.
9 Review(s)
KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
99 Review(s)
KBS #1 Thinner is a Low VOC paint thinner used for the thinning and clean up of RustSeal and our other KBS Coatings Paints.
27 Review(s)
Recently Viewed Items
