1. Home
  2. All Products
  3. Topcoats
  4. KBS Maxx
KBS Maxx
16 Reviews +Write a Review
KBS MAXX is a superior performance, two-component, low VOC, low HAPs polyurethane topcoat. Specifically designed for the automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
Quart: $59.95  |  Gallon: 199.95
5 Gallons: $899.95
In Stock, Ships Same Day!
Choose Options and Quantity
Part #: 80
Price Each: $59.95
356 Review(s)
This incredible all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
20 Review(s)
63 Review(s)
Recently Viewed Items
