RustBlast - Powerful Metal Acid Etch - Rust Remover - Pre-Paint Primer
111 Reviews +Write a Review
RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. RustBlast is ideal for removing rust from chrome surfaces.
8oz: $9 |Quart: $20 | Gallon: $38 | 5 Gal Pail: $180
Questions? Get Answers Here!
Part #: 3
Price Each: $0.00
Customers Also Bought...
20 Review(s)
116 Review(s)
427 Review(s)
The Frame Coater Kit is our complete quart size kit that includes enough products to Klean, Blast, and Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage and rust protection. You get Top Rated Rust Protection at a tremendous value! Detailed instructions included give you professional results.
153 Review(s)
Recently Viewed Items
