1. Home
  2. All Products
  3. Topcoats
  4. KBS Top Coater Aerosol
11 Reviews +Write a Review
KBS Top Coater is a superior aerosol spray paint formulated for maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints.
In Stock, Ships Same Day!
Choose Options and Quantity
Part #: 88
Price Each: $19.95
359 Review(s)
This incredible all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
20 Review(s)
64 Review(s)
202 Review(s)
13 Review(s)
KBS Top Coater is a superior coating formulated to be brushed, rolled or sprayed offering maximum coverage and professional looking results. KBS Top Coater is an ideal top coat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is a very high solids paint that does not run or sag, and gives at least twice the coverage of conventional paints.
7 Review(s)
Recently Viewed Items
