1. Home
  2. All Products
  3. Topcoats
  4. KBS UnderCoat - Solvent-Based Rubberized Undercoating
11 Reviews +Write a Review
KBS UnderCoat is a superior rubberized paintable undercoating that provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
In Stock, Ships Same Day!
Choose Options and Quantity
Part #: 77
Price Each: $9.95
348 Review(s)
KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean prepares your paint job with a clean surface. Try some today and see why customers say ...it's not really clean until it's KBS Klean'd!
92 Review(s)
61 Review(s)
Recently Viewed Items
