MATERIAL: Nitrile
OUTER SURFACE: Free from glove powder, Fully Textured
DONNING POWDER: Free from glove powder
COMPONENTS: 100% Acrylonitrile-butadiene (nitrile), a synthetic co-polymer
SHAPE: Ambidextrous, straight fingers, thumb and fingers in one plane. Beaded cuff.
SIZES: S, M, L, XL, 2XL
PACKAGING: 1000 gloves per case, by weight, 10 boxes per case 100 gloves per dispenser box, by weight
COLOR: Safety Orange
PIN HOLES AND VISUAL DEFECT: Assurance Action Sampling Inspection by destructive and visual test procedures
Width: Small: 95 mm (+/-5 mm) Medium: 106-111 mm (+/-5 mm) Large: 114-116 mm (+/-5 mm) X-Large: 119-121 mm (+/-5 mm)
Length M-XL: 235-245 mm
Thickness: Cuff: 4.7 mil Palm: 5.2 mil Finger Tips: 6.1 mil
5.0
NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay no complicated weighing or measuring required. Select BLACK, TAN, WHITE or GREY.
KBS Patch is an easy-to-use, UV/sunlight activated repair patch. The fiberglass-reinforced polyester patch creates long-lasting repairs. Perfect for making watertight, durable repairs on engine parts, decking, fenders, gas cans, drain pipes, water tanks, PVC pipes, plastics, Plexiglas, fiberglass, metal, wood, concrete and more.
