All KBS Coatings Products - Rust Prevention, Tank Sealers, Clear Coats and More
KBS Coatings Product Categories
RustBlast is a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. RustBlast is ideal for removing rust from chrome surfaces.
The Frame Coater Kit is our complete quart size kit that includes enough products to Klean, Blast, and Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage and rust protection. You get Top Rated Rust Protection at a tremendous value! Detailed instructions included give you professional results.
The Stop Rust Gallon Kit is our gallon size 3-Step System Kit that includes enough products to Klean, Blast & Seal any 200 sq. ft. area with 2 coats of paint coverage. You get Top Quality Rust Protection at a tremendous value! Detailed instructions included.
Our large 3-Step Rust Prevention Kit includes enough products to Klean, Blast, and Seal the entire underside of your car or truck, or any 100 sq. ft. area with 2 coats of paint coverage. Convenient all-inclusive kit at a tremendous savings!
Our Ultimate Quart Size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage AND Cavity Coater and Wand to seal up the inside of the frame. Top Quality Inside-Out protection at a tremendous value!
The All-In-One Chassis Kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this all-inclusive kit includes a pint of BlackTop topcoat for a permanent durable final finish which withstands dulling and fading caused by prolonged sunlight exposure.
This complete kit takes our popular Large Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes a Quart of BlackTop topcoat for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
The System Sampler Kit has everything you need to get started and try out the complete KBS system! The System Sampler Kit has a full 8oz of RustSeal that will coat and protect a 12 sq. ft. area with two coats so you can experience the quality and durability for yourself. The System Sampler Kit is our complete system in one all-inclusive package!
This complete All-In-One System Sampler Kit takes our popular System Sampler Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes 8oz of BlackTop topcoat for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
Everything you need to get started and try out our complete KBS system stopping rust from the inside out! A full 1/2 pint of RustSeal will cover an approx. 12 sq. ft. area with 2 coats and the Cavity Coater and Wand will seal up to 125 sq. ft. Experience the quality & durability for yourself. Our complete system in one package!
Everything you need to get started & try out our complete KBS system! A full pint of RustSeal will cover an approx. 25 sq. ft. area with 2 coats. Experience the quality & durability for yourself. Our complete KBS system in one package!
This complete Motorcycle Frame Coater Kit takes our popular System Sampler Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes 8oz of BlackTop topcoat for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
This complete kit takes our popular Large Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes a Quart of KBS Top Coater for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure.
DiamondFinish Clear Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear Aerosol does not yellow, crack or peel.
The Auto Fuel Tank Sealer Kit contains everything you need to clean, prep, and permanently seal up to 25 gallon tank. Detailed instructions included to give you professional and long-lasting results. Satisfaction guaranteed!
The Large Cycle Tank Sealer Kit is designed for the repair of larger sized motorcycles, generators, lawn mowers, tractors, snowmobiles, or other tanks up to 12 gallons. Detailed instructions included to give you professional, long-lasting results. Satisfaction guaranteed!
The Large Cycle Tank Sealer PLUS Kit is an all-inclusive tank stripping and tank sealing kit that contains everything found in our Large Cycle Tank Sealer Kit, "PLUS" a quart of KBS Strip to quickly remove any old failing sealers previously used to seal your tank. Detailed instructions included to give you professional and long-lasting results. Satisfaction guaranteed!
The Cycle Tank Sealer Kit is a complete kit designed to clean, prep, and repair your motorcycles, generators, lawn mowers, tractors, snowmobiles, utility tanks, or other small tanks up to 5 gallons. Detailed instructions included give you professional results. Satisfaction guaranteed!
The Cycle Tank Sealer PLUS Kit is our "PLUS" Kit that contains everything found in our regular Cycle Tank Sealer Kit "PLUS" a quart of KBS Strip to quickly remove any old failing sealers previously used to seal your tank. Detailed instructions included to give you professional and long-lasting results.
A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up a 25-50 gallon tank. Perfect for RV tanks, tractor tanks, diesel tanks, hold tanks, air compressor tanks, and more. Detailed instructions included. Satisfaction guaranteed!
Gold Standard Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
The KBS Tank Sealer System will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Whatever your tank holds will never touch the inside walls of your tank again. The KBS Tank Sealer System contains enough KBS Klean, RustBlast and KBS Tank Sealer to prep and permanently seal your tank.
The 4 Quart Special features four quarts of RustSeal to maximize savings and avoid waste. The 4 Quart Special is an incredible value for multiple larger size projects. Each RustSeal quart provides 2 coats of coverage for a 50 sq. ft. area. Mix or match colors.
Fusion SEP is an incredible all-purpose self-etching-primer that is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
KBS Fusion FPP - Flexible Plastics Primer is a grey flexible surface primer ideal for promoting adhesion between flexible surfaces like plastics, urethanes, wood, fiberglass, carbon fiber and most varieties of Topcoats. KBS Fusion Flexible Plastics Primer coats fast and easy providing a tight bond for superior paint adhesion and is ideal for hard-to-paint surfaces.
KBS Top Coater is a superior coating formulated to be brushed, rolled, or sprayed offering maximum coverage and professional looking results. KBS Top Coater is a direct to metal exterior grade coating that adheres permanently to steel and aluminum surfaces. KBS Top Coater is a very high solids paint that does not run or sag and gives at least twice the coverage of conventional paints.
KBS Top Coater is an aerosol spray paint formulated for maximum coverage and professional looking results. KBS Top Coater is an ideal topcoat paint for RustSeal when the area will be consistently exposed to sunlight. KBS Top Coater is an extremely high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints.
The KBS Top Coater Aerosol Camo 4 Pack is a superior aerosol spray paint formulated for maximum coverage, insane durability and professional looking results. The Camo 4 Pack includes all 4 camo colors: Flat Black Camo, Green Camo, Desert Tan Camo and Brown Camo. KBS Top Coater is a very high solids paint does not run or sag, and gives at least twice the coverage of conventional spray paints.
Cavity Coater is the perfect solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating designed for long term protection on all metal surfaces. Cavity Coater provides a self-healing film which provides incredible rust protection on hard to reach areas.
The Reusable Cavity Wand features a durable 360° spray tip to get in to hard-to-reach areas. This Cavity Wand attaches to the Cavity Coater Aerosol Can and is easy to clean and is engineered to require only an 1/8-inch hole eliminating the need to drill new holes.
The Trunk and Floorpan Repair Kit is a restoration kit that will save you money versus the cost of replacement. Restore your floor pan, trunk, or pickup truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
XTC is a high temperature/heat resistant coating formulated specifically to protect metal surfaces operating at temperatures from 500° F to 1500° F. With proper preparation, XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range, and is guaranteed not to burn off! Available in 10 great colors.
XTC Silicone Zinc Primer prevents corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. It functions much like galvanizing as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating. XTC Silicone Zinc Primer can be used alone as a finish paint. It withstands temps in excess of 1200F (648C).
Motor Coater is easy to apply, offers superb coverage and yields a self-leveling professional looking finish brushed or sprayed. These engine enamels provide deep, rich pigmented colors for excellent coverage. Your engine will be a show stopper at this DIY price!
The Motor Coater Kit has everything needed for a long-lasting paint job including good surface prep and high-quality coatings. You get proper prep, a rust preventative primer, and Motor Coater which is easy to apply, offers superb coverage, and yields a self-leveling professional looking finish brushed or sprayed. The Motor Coater Kit provides a deep, rich pigmented finish for excellent coverage.
KBS Strip is a powerful aircraft strength paint remover that sprays as a semi gel coat for fast and easy coverage. KBS Strip produces an even, unbroken film which seals and allows deep penetration through multiple layers of paint. KBS Strip will cling to vertical surfaces with minimal run or sag and offers low-odor technology. KBS Strip is the next generation of Paint Strippers containing no harmful Methylene Chloride.
KBS MAXX is a single stage, high performance, two-component (2K), low VOC, low HAPs, permanently UV stable polyurethane topcoat that can be applied by brush, roller, or sprayer. KBS MAXX is specifically designed for the indoor and outdoor applications including automotive, agricultural, fleet refinishing, marine, and heavy industrial equipment markets.
KBS MAXX Clear is a superior 2K Urethane UV Stable Clear Coat that provides a long lasting and durable finish while keeping its beautiful finish for years.
KBS UnderCoat is a superior rubberized paintable undercoating that provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
This superior undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
This VOC friendly waterbased undercoating provides protection in wheel wells, gas tanks, frames, and floor pans. KBS UnderCoat produces a very tough, yet flexible film with excellent adhesion, and helps prevent road salt from eating away at your car's metal and fiberglass.
KBS Rust Converter easily converts a rusty surface into a black, inert primed surface that is ready for painting and compatible with most topcoats and protects against future rust.
