KBS Coatings Diamond Finish Clear for Freshening Up Gelcoat
KBS Coatings DiamondFinish Clear can be used to permanently seal, protect, beautify and restore your boat’s gelcoat. User-friendly DiamondFinish Clear is a single part formula, high-gloss moisture cured urethane clearcoat that is UV stable, durable and extremely tough. DiamondFinish Clear also remains permanently flexible because of its use of advanced coatings technologies.
DiamondFinish Clear is a clearcoat that is able to perform in the toughest environments without yellowing, cracking or peeling. With minimal surface preparation, DiamondFinish Clear can be applied directly to faded gelcoats, cured basecoats, standard solid color paints, and single-part or two-part paints. It can also be applied to ferrous as well as non-ferrous metals including aluminum, alloys, brass, chrome and copper. Because of its superior adhesion properties, this clearcoat doesn’t have issues with delamination or peeling away from the surface.
DiamondFinish Clear is self-leveling and can be applied with a roller, conventional spray gun, or with a brush without leaving any brush marks, which are the bane for most clearcoat finishes. Tougher and harder than a two-part clearcoat, DiamondFinish Clear will withstand the harshest of chemicals including fuels, solvents, battery acid, hydrochloric acid and acetone.
For the best surface preparation before applying the clearcoat which ensures long lasting results and adhesion, use KBS Klean which is a concentrated, water-based, biodegradable formula industrial strength cleaner and degreaser. KBS Klean does not leave residues behind like solvent based cleaners which is key when you are clearcoating over the surface. The key with a fiberglass surface is to let the surface get bone dry after rinsing the KBS Klean off and before applying DiamondFinish Clear remembering that fiberglass is porous and tends to hold moisture in its pores.
For more information on DiamondFinish Clear, click HERE. For complete application directions on DiamondFinish Clear, click HERE.
Automotive Exhaust Paint Can Extend the Life of Your Exhaust System
Automotive exhaust paint can be used to restyle your exhaust system as well as protect it from rust and corrosion. Taking time to apply XTC Silicone Zinc Primer and XTC (Xtreme Temperature Coating) can not only increase pride of ownership but it can preserve and extend the life of your exhaust system for years. By spending less than a hundred buck you can save many times that in the long run as it helps to avoid having to replace exhaust components.
An exhaust system isn’t very well protected and as you drive it’s sprayed with water, salt and other debris that can cause damage and rust. When your car is parked in a garage it’s constantly exposed to moisture too. Even stainless-steel exhausts aren’t 100% corrosion proof.
Spraying off your exhaust system with water regularly will remove salt and particles that can trap moisture and cause rust. But to provide true protection, your exhaust system should be sealed with a coating to shield the surfaces of the exhaust system and keep moisture and debris from damaging it. That’s where the KBS Coatings XTC rust prevention system comes in.
The XTC rust prevention system consists of XTC (Xtreme Temperature Coating) and XTC Silicone Zinc Primer that work flawlessly together to prevent corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. The formulation of these products ensure they can withstand temperatures in excess of 1200F. The results are permanent and look great.
The coating procedure starts with applying a basecoat of XTC Silicone Zinc Primer. Before this is done you need to be sure the surface to be primed is dry and free from old paint or coatings, dirt, oil, rust, and other contaminants. Sandblasting prepares the surface best for paint adhesion. If you don’t have access to a sandblaster, use a wire wheel, wire brush, or sand using 60-80 grit paper. This will provide a surface equivalent to that provided by sandblasting.
Now it’s time to apply the XTC Silicone Zinc Primer. XTC Silicone Zinc Primer prevents corrosion of metal surfaces, can withstand temperatures in excess of 1200° F and functions much like galvanization as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating.
First, wash the surface well with KBS Klean at a 10:1 (water to KBS Klean) ratio, rinse and dry immediately and thoroughly before proceeding. Mask off areas not to be coated and protect adjacent areas with drop cloth or newspapers. For best results, apply when XTC when room temperatures are between 60-80° F. For details on XTC Silicone Zinc Primer application click HERE.
Next comes application of XTC – Xtreme Temperature Coating. XTC is a high temperature/heat resistant automotive exhaust paint designed to protect metal surfaces operating at temperatures from 500° F to 1500° F. XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range and is guaranteed not to burn off.
XTC will not peel, flake or chalk and is resistant to scratching or marring. XTC is available in 10 colors which allows you to do some unique styling if you wish. Like XTC Primer, XTC is available in aerosol spray can form or in containers for application by brush, roller, or spray equipment. For more information on applying XTC click HERE.
The XTC rust prevention system is the perfect solution for restyling your exhaust system and protecting it from corrosion!
For more information on XTC Silicone Zinc Primer click HERE.
For more information on XTC – Xtreme Temperature Coating click HERE.
Lawnmower Deck Rust Removal and Painting with RustSeal
Lawnmower Deck Rust Removal and Painting with RustSeal from KBS Coatings
This video from KBS Coatings describes the use of the KBS System Sampler and KBS Large System Sampler for removing rust from a lawn mower deck and sealing the lawn mower deck to prevent new rust from forming.
Your lawn mower is a significant investment and with proper maintenance it can work better and last longer. Grass clippings, dirt and debris can eventually abrade the paint on the underside of the deck until the metal is exposed. This can cause rust to form, which can eventually eat through the metal. Meanwhile, grass clippings that become caked on the mower deck can hold in moisture, which only makes the rust problem worse. Removing corrosion and applying KBS RustSeal rust preventative coating, is the perfect solution for not only extending the life of the mower, but providing a glossy slick surface that is more easily cleaned of grass clippings: A surface free of caked on clippings can improve the performance of the mower.
With proper maintenance your lawnmower can last many years and KBS Coatings is here to help.
Impressed with KBS Products On My 72 inch Mower Deck
Impressed with KBS Products On My 72" Mower Deck
In these times of social distancing and stay at home orders, may of us are looking at projects around the house that may be long overdue. Many of our customers have turned to our paint products for restoring their equipment that may be rusty now or may rust down the road if not coated with a rust preventative coating.
Matthew P tells us: "I just wanted to say how impressed I've been with KBS products. I recently purchased a 72" finish mower that was mechanically sound but had lots of surface rust. I started with the underside of the deck and used the Frame Coater Kit with fantastic results. For the top of the deck I used the Klean/Blast/Seal process, then KBS Top Coater and then DiamondFinish Clear. I couldn't be happier with the results and I fully expect this thing to outlast me. Also worth mentioning is that KBS customer service is first-rate. They guided me on what products to use and delivery was super fast. Looking forward to more projects!”.
The KBS Products that he used are ideal for restoring a mower deck. The KBS Klean and RustBlast will prep the steel surface so that the rust is removed and the surface is etched leaving an anchor pattern on the surface of the metal that is ideal for paint adhesion. RustSeal prevents rust and is extremely durable which is a necessity for a mower deck on both the topside and the underneath.
The KBS Top Coater is a high solids UV stable coating that covers extremely well and leaves a beautiful finish that is very visible and also extremely durable. DiamondFinish Clear is a water clear coating that adds gloss and provides additional protecion and durability. Using the combination of all of those products left him with not only a beautiful finish but a finish that will be very easy to wash and clean after each use. The investment in a high quality coatings system will protect his equipment investment for years to come.
Motorcycle Engine Paint Makes Your Bike Look Great
In these times of social distancing you may be looking for projects to do around the house. Now is a good time to restore the finish of your motorcycle’s engine or perhaps even restyle it. The KBS Motor Coater Kit provides what you need to prepare and paint your motorcycle’s engine with professional results.
The KBS Motor Coater Kit is designed to be user-friendly, reduce labor time and provide a great looking and long-lasting finish. This all-inclusive kit contains KBS Klean to clean and degrease the frame, RustBlast to remove surface rust and etch the surface for excellent paint adhesion and Motor Coater, which is an engine enamel with deep, rich pigmented colors for excellent coverage. KBS #1 Thinner is also included for thinning the motorcycle engine paint when applied with a spray gun and for clean up.
Motor Coater is a high performance and high gloss paint that can withstand temperatures of up to 450°F. It matches OEM standards, will not blister, flake, crack or peel and is impervious to oil, transmission fluid and gas. Motor Coater is easy to apply, offers superb coverage and is self-leveling meaning the brush marks flow out. Motor Coater is currently available in at least 39 colors.
To ensure a durable and long-lasting Motor Coater finish, the engine surface must be properly prepared. Dirt, grease, flaking rust and other contaminants, as well as loose paint must be removed before painting. Proper cleaning makes the difference between poor results and results that can last generations. Motor Coater can be directly applied to sand blasted surfaces and requires no other prep beyond blowing off the loose dust with clean air. Plastic media, bead or soda-blasted surfaces do not provide the adequate amount of abrasion needed for direct Motor Coater application and will require use of RustBlast. For all other applications, simply proceed as described below. Remember to always allow products and surfaces to adjust to room temperature before prepping and painting.
Start by using a wire wheel or brush or 320 grit sandpaper to remove any flaking rust or loose paint. Next, clean with KBS Klean concentrate mixed one to one with hot water. The warmer the water, the more effective and powerful the cleaning action of KBS Klean will be. For general purpose cleaning, apply liberally and scrub surface for 5-10 minutes. For heavy-duty cleaning, you can extend soaking time up to 24 hours or more as necessary. Use a bristle brush or scouring pad to speed up the cleaning of heavily soiled surfaces. Re-treat surface as necessary until clean. Rinse clear and let dry.
Liberally apply RustBlast full-strength to a clean and dry surface using a spray bottle or brush. Re-apply RustBlast often to continually keep the surface wet for a minimum of 30 minutes. Moderately or heavily rusted or corroded surfaces will require more soak time typically about an hour or so. Do not allow RustBlast to dry on the surface before rinsing. After treatment, rinse thoroughly with water and then allow surface to dry or dry the surface completely before coating. Items treated with RustBlast can remain uncoated for up to 7 days before sealing depending on environmental conditions.
The Motor Coater Kit provides Motor Coater in a pint can. The motorcycle engine paint can be applied with a brush, roller or spray gun. Motor Coater has good self-leveling characteristics so brush marks will flow out nicely. As with all other paints, it is always best to spray any of the metallic colors for the best possible cosmetic finish.
Before using, stir the Motor Coater for several minutes to obtain the best uniform sheen and finish. Stir Motor Coater thoroughly for several minutes to obtain even color mixture. Do not shake as it can form air bubbles. Stir often during the course of painting. Thinning may be required for some spray applications. Reduce 5%-10% if needed using the included KBS #1 Thinner only.
In most cases, a single full coat of Motor Coater will cover completely with full color depth. If desired, a second coat may be applied within 30 minutes or after 7 days. As with most paints, two thin coats are better than one heavy coat. Average cure time to touch is 2-4 hours.
While you do not need to clear coat over Motor Coater you can apply DiamondFinish Clear or KBS MAXX Clear over Motor Coater for additional durability and gloss but be sure to wait seven days before apply the clear coat.
The KBS Motor Coater Kit is just what you need for improving the looks and protecting your motorcycle engine. Our motorcycle engine paint will not only increase pride of ownership, but it can increase resale value as well!
For more information on the KBS Motor Coater Kit click HERE.
Motorcycle Exhaust Coating Stops Corrosion, Looks Great, and is a Cost-Effective Solution
A rusted motorcycle exhaust system looks terrible. It can make your bike look aged and generally detract from its appearance. The rest of the motorcycle could look great, but the exhaust is such a large and noticeable part of the bike that unless the rust is stopped, rust will progress to the point where the metal is weakened or even perforated. You could purchase a new exhaust system but that could cost a few hundred dollars or even thousands. Lucky for you, the KBS Coatings XTC rust prevention system provides a far more cost-effective solution.
The XTC rust prevention system consists of XTC (Xtreme Temperature Coating) and XTC Silicone Zinc Primer that work together to prevent corrosion of metal surfaces exposed to high heat, high humidity, condensation and salt air. The formulation of these products ensure they can withstand temperatures in excess of 1200F. The results are permanent and look great.
The first step in restoring a motorcycle exhaust using the XTC system is to ensure the surface to be primed is dry and free from old paint or coatings, dirt, oil, rust, and other contaminants. Sandblasting is the ideal surface preparation as it leaves the ideal anchor pattern for paint adhesion. If you don’t have access to a sandblaster, use a wire wheel, wire brush, or sand using 60-80 grit paper. This will provide a surface equivalent to that provided by sandblasting and allow the desired surface profile or anchor pattern.
Now it’s time to apply the XTC Silicone Zinc Primer. First, wash surface well with KBS Klean at a 10:1 (water to KBS Klean) ratio, rinse and dry thoroughly before proceeding. Mask off areas not to be coated and protect adjacent areas with drop cloth or newspapers. For best results, apply when XTC when room temperatures are between 60-80° F.
XTC Silicone Zinc Primer prevents corrosion of metal surfaces, can withstand temperatures in excess of 1200°F and functions much like galvanization as it locks itself to bare metal surfaces leaving a perfect primed surface for top coating. XTC Silicone Zinc Primer is free of fluorocarbons, lead, and chromates and is grey in color.
XTC Silicone Zinc Primer is available in aerosol spray can form. For larger applications by brush, roller, or spray equipment, XTC Primer is also available in quart, gallon or five-gallon containers. For purposes of this article we will discuss application by aerosol spray can.
Hold the aerosol can 12-15 inches from surface and apply using steady, even strokes. Apply two light coats, allowing 15 minutes drying time between coats. Allow the primed surface to dry a minimum of 30 minutes before top coating with the KBS Xtreme Temperature Coating.
Next comes application of XTC – Xtreme Temperature Coating. XTC is a high temperature/heat resistant motorcycle exhaust coating designed to protect metal surfaces operating at temperatures from 500° F to 1200° F. XTC provides outstanding adhesion, film integrity, weathering, and thermal shock-resistance throughout this entire temperature range and is guaranteed not to burn off. XTC will not peel, flake or chalk and is resistant to scratching or marring. XTC is available in 10 colors which allows you to do some unique styling if you wish.
This motorcycle exhaust coating also has an interesting property in that it acts as an insulator that reduces the surface temperature of the exhaust system. Don’t get us wrong, it will still get hot, but not quite so. The heat is retained with the exhaust system which improves exhaust gas velocity and can increase horsepower.
Like XTC Primer, XTC is available in aerosol spray can form, or in containers for application by brush, roller, or spray equipment. Again, for purposes of this article we will discuss application by aerosol spray can. For best results, apply when spray can, and room temperatures are between 60-80° F. Hold aerosol can 12-15 inches from surface and apply using steady, even strokes. Apply a minimum of two light coats, avoiding drips and runs. Allow 15-30 minutes drying time between coats. Only apply the number of coats needed to get the desired coverage. Do not apply more coats that you need for coverage as this can have adverse consequences. As with all KBS Products, multiple very thin, covering coats is always the best practice as heavy applications can lead to reduced adhesion and coating life. Allow painted surface to dry a minimum of 8 hours before subjecting to high heat.
With the KBS Coatings XTC rust prevention system you can stop rusting, preserve your exhaust system, and make it look great. Plus, consider the cost savings. Would you rather spend $40.00 on KBS motorcycle exhaust coating, or several hundred or thousands of dollars on a new exhaust system?
For more information on XTC Silicone Zinc Primer click HERE!
For more information on XTC – Xtreme Temperature Coating click HERE!
KBS Fuel Tank Sealer System Removes Rust and Restores the Inside of Your Tank to Like New
Rusting and varnish in a fuel tank can create problems. First, rust can create pin holes from which fuel can leak and it can also weaken seam welds creating a fire hazard. Vehicles with in-tank fuel pumps can have issues as fine rust particles pass through the pump pickup strainer and into the pump causing damage. Further, rust particles can collect in fuel filters restricting fuel flow meaning the vehicle can find itself getting enough fuel at idle, but then not enough when accelerating. Particles can also clog fuel injectors and carburetors. Rust in fuel tanks is more of an issue now than it was in the past since today's ethanol-gasoline blends are more corrosive than non-ethanol gasolines of the past.
If your fuel tank has rust there are two ways fix the problem: Replace the tank with a new one or take steps to clean the inside of the tank, remove the rust, and seal the inside with a fuel tank sealer. Replacement of the fuel tank can be very expensive especially in the case of some classic cars where the tanks are very pricey. And even a new tank that has not been sealed will start to rust causing the same problems. Of note, if you have a diesel vehicle, diesel sludge contamination is another fuel tank issue to consider. Diesel sludge is an algae-like substance that adheres to the tank surface or at the fuel water interface. The sludge settles to the bottom of a fuel tank and can clog filters when the vehicle is fueled. A good tank cleaning will help with this problem.
KBS Coatings offers the simple to use Tank Sealer System as an effective, high-quality and economical solution to clean, de-rust and seal your fuel tank. The KBS Tank Sealer System will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Whatever your tank holds will never touch the inside walls of your tank again.
The KBS Tank Sealer System is made up of three components. KBS Klean, RustBlast and Gold Standard Tank Sealer.
KBS Klean is a powerful cleaner that deeply penetrates and removes soil and varnish without leaving harmful residues or emitting noxious fumes. KBS Klean is a super concentrated, water-based, biodegradable formula that is crazy powerful and an excellent alternative to flammable solvents and hazardous chemicals.
KBS Klean is designed to be diluted with water and a full-strength dilution is 1-part water (hot water works best) with 1-part KBS Klean. Pour the bottle and water into the tank, place some metal objects like nuts and bolts in to act as agitators and shake the tank up. Let it soak for 45 minutes then flush with water until suds stop coming out. You can repeat as many times as needed.
The next step is RustBlast, a powerful rust remover, zinc phosphate pre-primer and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides and tarnish from the inside of the tank. It will etch the surface and leave a zinc phosphate coating to ensure a strong bond with the Tank Sealer. The zinc will protect against flash rust in case the Tank Sealer can’t be applied right away.
When working with RustBlast, leave the agitators, which were used in the previous step, in the tank. Shake the tank thoroughly and let the RustBlast soak for about 45 minutes, rotating the tank around every ten minutes or so to etch all surfaces. Then pour out the RustBlast in a container, but don’t dispose of it yet in case the procedure needs to be repeated. Rinse the tank out well with water and inspect to be sure all the rust is gone. If not, repeat the procedure. After the rust has been removed the tank needs to be thoroughly dried. It’s best to use a heat gun or blow dryer to ensure it is completely dry. Don’t forget to remove the agitators!
The grand finale is application of Gold Standard Tank Sealer, a superior single component, ready-to-use fuel tank sealer formulated for coating the inside of metal, aluminum and fiberglass tanks. Gold Standard Tank Sealer is an easy-to-use single application coating that cures into a tough fuel impervious seal. The entire tank including pinholes and weld seams are permanently sealed to prevent the return of rust and corrosion and clogged carburetors.
After pouring in the Tank Sealer, leave it there for 45-60 minutes. Frequently rolling the tank to be sure it coats all interior surfaces and into the seams. Be sure that all remaining fuel tank sealer is completely drained from the tank as you don’t want to leave any pools. The tank can always be propped up and left to drain. It is very important that the sealant be allowed to cure for four days before putting in any fuel.
Rust and varnish accumulation in fuel tanks is a big problem. The KBS Tank Sealer System is an excellent solution.
For more information on the KBS Tank Sealer System, click HERE.
The Motorcycle Frame Coater Kit Has Everything Needed to Remove Rust and Prevent Rust In The Future
Rust Preventive Motorcycle Frame Paint – The Motorcycle Frame Coater Kit Has Everything Needed to Remove Rust and Seal Metal Away from Moisture
When restoring a motorcycle, refinishing the frame is a time-consuming process. If the frame is rusty you can count on spending additional time on preparation. Further, once prep is completed, extra care must be taken to ensure further rusting is prevented. KBS Coatings addresses this with the Motorcycle Frame Coater Kit, which is specifically engineered to be user-friendly, reduce labor time and provide a great looking, long-lasting and druable rust preventative finish.
This all-inclusive kit contains KBS Klean to clean to clean the frame, RustBlast to remove surface rust and etch the surface leaving an ideal anchor pattern for paint adhesion, RustSeal which is a rust preventative motorcycle frame paint and BlackTop which is a durable topcoat for a UV stable permanent final finish. KBS #1 Thinner is also included for those who wish to spray rather than brush the RustSeal and BlackTop. This tried and true system has customers raving. The Motorcycle Frame Coater Kit provides coverage for 12.5 square feet of surface area.
The first step of the process is to remove loose or scaly rust and/or paints and coatings with a wire brush, wire wheel or sandpaper. Next scrub the frame with KBS Klean, which provides a clean surface for your motorcycle frame paint job. KBS Klean is a powerful cleaner that deeply penetrates and removes stubborn soil from most surfaces without leaving harmful residues or emitting noxious fumes. KBS Klean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents and hazardous chemicals. KBS Klean is designed to be diluted with water and a full-strength dilution is 1-part water with 1-part KBS Klean.
The next step is application of RustBlast, a powerful rust remover, zinc phosphate pre-primer, and metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnish from most metal surfaces. It will gently etch the surface and leave a zinc phosphate coating to ensure a strong bond with any paint. RustBlast is applied full strength to a clean surface and needs to be kept wet for at least 30 minutes or more. The RustBlast step is completed by rinsing with water and letting the surface dry thoroughly even the weld spots which tend to hold water.
Now it’s time to apply RustSeal, a rust inhibitive and rust preventative paint that chemically bonds to metal, including rusted metal, to form a flexible yet rock-hard, non-porous barrier. RustSeal will not crack chip or peel. RustSeal is user-friendly and works by isolating metal from moisture and without moisture present, steel can't rust. RustSeal is formulated with fast evaporating solvents that allow the paint to cure quickly and bond to the frame which locks out water and air to avoid rust and corrosion. Slow evaporating solvents are also part of the formulation and remain longer to allow brush marks to flow out. Further, RustSeal contains additives that allow gases, created during the curing process, to escape meaning bubbles don’t form in the applied finish and compromise the appearance and integrity of the coating. RustSeal is incredibly tough and extremely resistant to abrasion and impact yet provides a smooth beautiful finish that resembles the look of a powder coat or ceramic coat. RustSeal can be applied by brush, or with a spray gun. It is recommended to thin RustSeal 5-10% with KBS #1 Thinner using a spray gun. RustSeal is always applied in thin coats and typically, two coats is enough to coat the surface with proper coverage.
The last step in the frame refinishing process is to apply BlackTop Chassis Paint. RustSeal is not intended for use as a final finish when used where the coated surface will be consistently exposed to sunlight. Repeated or prolonged exposure to direct UV light will cause cosmetic alteration to its color and sheen. BlackTop is a permanent, high-performance, moisture-cured and UV stable protective high-performance coating that’s specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure and go right over RustSeal. BlackTop dries to a rock hard yet flexible coating that is incredibly durable. As with RustSeal, BlackTop has superior flow out and leveling and can be applied by brush, or by spray gun when diluted 5-10% with the included #1 Thinner.
With the Motorcycle Frame Coater Kit, you can restore a motorcycle frame with an excellent and long-lasting finish that will look great and prevent rust and corrosion. Your bike will be the talk of all of your buddies!
To learn more about the Motorcycle Frame Coater Kit, CLICK HERE.
RustBlast is a Powerful Rust Remover - Keep Surface Wet
Keep Surface Wet and Then Rinse With Water
This tip for RustBlast is a simple one but just as easily misunderstood. As a powerful rust remover and acid etch, RustBlast will only etch metal and dissolve rust while it remains damp. By letting RustBlast dry before reapplying you might allow an excessive amount of zinc phosphate to build up.
If RustBlast isn't rinsed off (RustBlast should always be rinsed at the end) this excess zinc phosphate can create a barrier that could keep RustSeal from adhering property.
By making sure that you both reapply RustBlast while wet, and rinse RustBlast off when done, you ensure that RustBlast will do the premium job that it's designed to do.
Seal Your Lawnmower Deck To Prevent Grass From Sticking
Remember Your Lawnmowers!
Pick a glossy finish like Gloss Black RustSeal for the slickest surface and watch the grass fall right off and not clog up your mower. Because the underside of most mower decks is coarse, we always apply at least 3 thin coats for this application.
Apply RustSeal In Thin Coats
APPLY RUSTSEAL IN THIN COATS
Remember that RustSeal should be applied in THIN coats. Applying too heavily, will cause running and/or sagging on vertical surfaces, and possible bubbling on horizontal surfaces. As RustSeal cures, it releases a small amount of carbon dioxide. If allowed to "puddle", the top of the RustSeal directly exposed to the ambient humidity in the air (the actual catalyst for RustSeal) will begin to "skin" over. This "skinning over" is much like that of chocolate pudding and blocks the release of the afore mentioned carbon dioxide causing bubbles. By applying thin coats, this film cures through and through all at once.
MORE TIPS & TRICKS
RustSeal Fix-It Guide: This guide helps you quickly identify the causes of and the recommended solutions for the most common issues that could occur for RustSeal.
Tip of the Month – Tank Sealer
PATIENCE IS A VIRTUE THAT WILL BE REWARDED...
Over the years, one of the BEST TIPS that we can give to people who are sealing a tank is to BE PATIENT. Proper prep and sealing IS NOT a lunch hour project. The KBS 3 Step System works perfectly if the Instructions are followed which includes:
- Be Patient and allow the KBS Klean the time to thoroughly dissolve all the oily fuel residues before rinsing.
- Be Patient and allow the RustBlast to soak and disintegrate the rust in your tank before rinsing.
- Be Patient while waiting for the tank interior to dry completely as the tank can NEVER be too dry!
- Be Patient and allow the tank to cool to room temperature before applying the sealer.
- Be Patient when sloshing the sealer around to insure complete coverage.
- Be Patient when draining any & all excess sealer from the tank.
- Be Patient while waiting for the sealer to cure.
